B18B ???????'s
Old Sep 14, 2002 | 02:11 PM
TURBOED-TEG's Avatar
Default B18B ???????'s
I have an OBD 1 95 Civic DX and I plan on swapping in a 97 OBD2 B18b, I also plan on boosting it in the future...would I want to use the DX ecu or buy a P74 OBD1 ecu for the LS to run properly?
Old Sep 14, 2002 | 02:12 PM
Civicdrgrcr's Avatar
From: WTF DC Racer No Way Turbo Washington., DC, USA
Default Re: B18B ???????'s (TURBOED-TEG)
Check out my signature. I am selling a 93 LS ecu which is still a obd1 ecu plugs right up to any civic/integra from 92-95. I also have the wiring harness. ETC!!
Old Sep 14, 2002 | 02:15 PM
Default Re: B18B ???????'s (Civicdrgrcr)
I could use the ecu, but I don't think I need the harness right?? My stock harness will bolt up correct?
Old Sep 14, 2002 | 05:24 PM
If I am not mistaken yeah it should bolt up. But check my signature out for stuff I am selling.
Old Sep 14, 2002 | 06:29 PM
ttt
Not to discredit you but I would like some more ppl's input
Old Sep 14, 2002 | 07:13 PM
shermanyang's Avatar
if i'm not mistaken, the 93 ls ecu is totally different from the 94-95 ecu's. i have a 99 B18B1 motor and i had to get a 94-95 ls ecu. so just letting you know that you'll need a 94-95 ecu, not a 93.
Old Sep 15, 2002 | 12:25 AM
Default Re: B18B ???????'s (shermanyang)
Is that the only thing that you had to do, Just replace the ECU with a 94-95 model and everything just plugged in ok
Old Sep 15, 2002 | 09:11 AM
Foozball26's Avatar
why not go for like a 94 - 95 LS motor so you can stay OBD1 so you can use things like hondata and also not have the worries of converting to OBD2
Old Sep 15, 2002 | 09:37 AM
Default Re: B18B ???????'s (foozball-26)
with an ODBII motor, you don't have to use the extra O2 sensor or all the other little ODBII plugs. all you need to so is rewire the distributor and the injectors and that's it. it's really basic and easy to do if you have your ODBI plugs to compare with your ODBII. after that all you need is the ODBI ecu. if you need help on doing this swap, just email me and i'll be happy to walk you through it. remember, you learn something new everytime you actually attempt to do it.
Old Sep 15, 2002 | 05:16 PM
Can you email me some pics or a detailed list of instructions...I don't want to get started and then not have any reference!
BTW the reason I am going with the OBD2 motor is because I am getting the long block for $600.
Old Sep 15, 2002 | 07:20 PM
It bolted up to my 92 civic when i had my 95 b18b turbo hatchback.
Old Sep 16, 2002 | 07:33 AM
ttt
ted
Feb 14, 2005 03:30 PM
3 plus 1
Feb 20, 2004 10:31 AM
kholmes
Aug 28, 2003 06:40 AM
Sassafrass
Jun 20, 2003 10:54 PM
