b18a with darton sleeves with 84mm pistons or crv bottom end?
i have an ls/vtec that i need to resleeve the motor so i have to ether do the b18 or should i just get a crv motor the hole point of this motor is to f**k SH*T UP if anyone could let me know what motor set up i should use and what turbo i should use i was thinking about a t 60 so let me now what you think
Re: b18a with darton sleeves with 84mm pistons or crv bottom end? (Frankinfreak300)
if you are going to resleeve the b18a and bore to 84mm that would be the exact same bore as the b20. depending on the amout of boost you are going to use you'll have to resleeve the b20b also. so since you have the ls motor why don't you keep the ls block and do as you intended.
Re: b18a with darton sleeves with 84mm pistons or crv bottom end? (Turbocivic94)
listen to the 2 people above. No need to go get a crv block waste of time when you have the ls block
Go with the B18a with a Darton Sleeve kit. The B20 block is a poorly cast block compared to a B18.
Good Luck!
Good Luck!
Re: b18a with darton sleeves with 84mm pistons or crv bottom end? (redturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic »</TD></TR><TR><TD CLASS="quote">listen to the 2 people above. No need to go get a crv block waste of time when you have the ls block</TD></TR></TABLE>
WhoDoYouThink
09-28-2005 01:41 PM
Boostless97Lude
11-20-2002 07:19 PM
