B18a/b vs. D16z6
Old May 15, 2004 | 02:02 PM
1tyme's Avatar
Default B18a/b vs. D16z6
i've done some searching and found that given the same amount of boost the B18a/b puts out the around the same hp as a D16z6. Yes i know the b18's can handle more boost and are better motors for high boost but what about 7-10 psi.
i have a d16z6 with a greddy kit boosting 10psi. my fren with an LS/VTEC is faster he has a pretty constant pull from me. I was planning on getting a B18 to boost 10psi on but by searching for dynos comparing stock b18a/b bolck and stock d16z6 blocks on 7-10psi are putting out similar numbers.
Old May 15, 2004 | 02:56 PM
1point5CRX's Avatar
Default Re: B18a/b vs. D16z6 (1tyme)
b-series will have more torque and can accelerate right outta the hole
Old May 17, 2004 | 08:19 PM
Vera's Avatar
Default Re: B18a/b vs. D16z6 (1point5CRX)
d16z6 weights 100lbs less than that b series .. put a bigger turbo on your d heh
Old May 17, 2004 | 08:49 PM
z6's Avatar
z6
first of all D series are like factory stroked motors almost and they will make more torque
Old May 17, 2004 | 09:17 PM
Jockobo's Avatar
Default Re: (z6)
i went from a d series and kept the d series turbo stuff (t-25, hf manifold) and put it on a ls and it's only slightly faster (can't directly compare track times because the d series motor was shot and I added more weight with a interior when i went to b) you can definitely tell the difference in torque and on the highway on a top end pull so basically the b is funner to drive but at the track they might be somewhat equal if all things are equal (turbo, etc.) that's my 2 cents
Old May 17, 2004 | 10:21 PM
Vera's Avatar
Default Re: (Jockobo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jockobo &raquo;</TD></TR><TR><TD CLASS="quote">i went from a d series and kept the d series turbo stuff (t-25, hf manifold) and put it on a ls and it's only slightly faster (can't directly compare track times because the d series motor was shot and I added more weight with a interior when i went to b) you can definitely tell the difference in torque and on the highway on a top end pull so basically the b is funner to drive but at the track they might be somewhat equal if all things are equal (turbo, etc.) that's my 2 cents </TD></TR></TABLE>
you put the hf mani on a b series ?? .. wouldnt think that would even fit up
Old May 17, 2004 | 10:46 PM
Jockobo's Avatar
Default Re: (Vera)
yea it barely fit on there...it's missing 2 bolts though but it still seals up ok.
Old May 17, 2004 | 10:53 PM
1tyme's Avatar
anymore info on this? i'm debating wether to go LS turbo or just skrew turbo and go LS/VTEC either way i go would cast around the same to me. was thinking about tuning my aohc turbo but not quite confident on what the results would be.
Old May 18, 2004 | 04:57 AM
beerbongskickass's Avatar
Last time I was at the dyno I made 216whp/181wtq @ 10 psi with my d16z6. My buddy made 198whp/216wtq @ 11 psi with his b18a.
Old May 18, 2004 | 05:55 AM
USDM 4G VTEC's Avatar
last time i checked
i made 121 whp and 107 wtq
and on my graph i made more tq on low and mid range up to like 5k than most B16 ( ex, compared to my cousins 143 whp )
camcar
14
Oct 19, 2007 02:07 AM
jwcrx23
May 4, 2006 11:43 PM
Sinner
Oct 20, 2005 08:41 PM
Del_Slo_1
May 3, 2004 10:08 PM
civicwagonman
Feb 20, 2002 05:35 PM
