b17a block...with b16crank and rods?
Old Apr 25, 2002 | 01:05 PM
BoostedSi's Avatar
Default b17a block...with b16crank and rods?
If i got a b17a block could i use my b16a crank, rods, and pistons in it?
Old Apr 25, 2002 | 01:08 PM
b18bturbo's Avatar
Default Re: b17a block...with b16crank and rods? (BoostedSi)
you gotta get custom rods and pistons. if you do stay with the b16a crank plus you have line hone everyhting
Old Apr 25, 2002 | 01:16 PM
BoostedSi's Avatar
Default Re: b17a block...with b16crank and rods? (b18bturbo)
Old Apr 25, 2002 | 01:20 PM
b18bturbo's Avatar
try to find a b17a crank and you should be easier that way.
Old Apr 25, 2002 | 01:23 PM
dust's Avatar
I thought the B16 and B17 blocks were essentially the same? They have the same deck height. Am I missing something here?
Old Apr 25, 2002 | 01:24 PM
Shaun K's Avatar
B16A and B17A blocks are the same dimensionally, it's just the internals and the block stamp that make it a B17A. You can drop B16A crank/rods/pistons in it and it will be a 1.6. You don't need custom rods or pistons if you are using all B16A internals.
Old Apr 25, 2002 | 01:26 PM
b18bturbo's Avatar
Default Re: b17a block...with b16crank and rods? (Shaun K)
Thats true if you destroke it ... but you still have to line hone the main caps to match the crank or your freaking spin some ****
BoostedSi's Avatar
thats wut i thought....hmm. Are u sure about this? cuz i have just cracked the sleeves on my b16a block and i found a pretty cheap b17a block. I was just gonna swap the blocks and use all my b16a internals.
Old Apr 25, 2002 | 01:28 PM
BoostedSi's Avatar
Is it expensive to line hone the main caps?
Old Apr 25, 2002 | 01:32 PM
BoostedSi's Avatar
one more question...if i do get a b17a crank would i need to get new pistons and rods too?
Old Apr 25, 2002 | 01:39 PM
Shaun K's Avatar
please explain to me why you'd have to line hone the main caps in a B16A/B17A block to put B16A crank in it?
Old Apr 25, 2002 | 01:41 PM
Katman's Avatar
YES you could. I did the reverse with my old engine.....B17A internals in a B16A3 block. I bought all new bearings and rings though when I did it...but everything worked just fine.
I have no idea why B18turbo says: Thats true if you destroke it ... but you still have to line hone the main caps to match the crank or your freaking spin some ****
I didn't have to do that and my engine ran fine up until the point of my car getting stolen, so there.
Old Apr 25, 2002 | 01:48 PM
Gmedalion's Avatar
I have a B17A crank for sale if you want it.
Old Apr 25, 2002 | 01:50 PM
BoostedSi's Avatar
Thanks guys, thats all i needed to hear. I'm gonna get that b17a block now. Thanks again.
geoology
Oct 12, 2012 09:53 AM
executedace
Jun 5, 2010 11:27 PM
chuisek9
Apr 15, 2008 06:08 PM
B16b2b
May 17, 2003 06:59 AM
Deltax75
May 20, 2002 09:03 AM
