B16b stroked...looking for boost
Old Jul 19, 2006 | 11:29 AM
B16b-EJ8's Avatar
Default B16b stroked...looking for boost
I have a B16b with the spoon 1.8l stroker kit so my compression is like 11:3:1 so im thinking thats a little on the high end for boost. If i were to purchase some lower compression pistons and put those on would i need to change anything else for boost. Not looking for big numbers 250-300whp is fine as a daily for me.
Old Jul 19, 2006 | 11:39 AM
Turbo O's Avatar
Default Re: B16b stroked...looking for boost (Stroked B16b-EJ8)
yea the number that you are looking for could be done with the setup you have now. you would need a small turbo and a very fine tune. but i think 5psi could get to the 250hp range. and the 5psi would be "on the safe side". but if I were you i would get the lower comp pistons. just make sure you get them the same size pistons so it still goes with you storker setup.
Old Jul 19, 2006 | 11:45 AM
B16b-EJ8's Avatar
Good call... thanks for the info. any other thoughts from any others
Old Jul 19, 2006 | 12:02 PM
sohc_turd's Avatar
Default Re: (moops vs moors)
I say go with a decent size turbo (more efficient) + alky injection and boost like normal.
Dre90
Mar 26, 2010 02:36 PM
stefz
Jan 29, 2009 08:22 AM
snaileg
Nov 8, 2006 04:11 PM
2000SiDriver
Apr 14, 2004 08:08 PM
X2BOARD
Apr 18, 2002 10:51 AM
