b16b good with boost ?
Old Feb 12, 2010 | 07:03 AM
chrisa_1's Avatar
Default b16b good with boost ?
well one of my friends has a b16b laying around and i was thinking of swapping that in my ek and boosting
my hp goal for this summer would be around 300 whp
how much who can a b16b handle on stock internals ? this will prob also be used as a daily driver
thanks
Old Feb 12, 2010 | 07:26 AM
boostedeg302's Avatar
Default Re: b16b good with boost ?
Search my friend. It has been covered numerous times.
Old Feb 12, 2010 | 09:27 AM
Schister66's Avatar
Man U FTW
The higher static compression of the B16b would be the only concern. If you have access to a higher octane fuel such as E85, 100oct or race gas, then the higher static comp isn't much of an issue. The compression merely limits what you can achieve on a certain grade fuel. With your average premium 91-93oct fuel, you may be limited to less than 300whp.
Old Feb 12, 2010 | 04:56 PM
chrisa_1's Avatar
i was reading somewhere that a b16b uses the same bottom end as a b18c but has a crank with a longer throw if i where to change that to a b18c crank wouldn't that lower the compression ?
and i would be able to make more power ?
or maybe get low compression pistons and stronger connecting rods
Hondaaaaa
Feb 16, 2008 04:16 AM
HCivic45
10
May 21, 2005 04:09 PM
BLITZ
Oct 29, 2002 07:59 PM
pkripper
Apr 30, 2002 08:05 PM
