B16a3 Turbo help....
Old Jul 30, 2005 | 04:08 PM
DC-4-Drew's Avatar
Default B16a3 Turbo help....
THnKs
Modified by LSvtec delsol at 10:56 PM 7/31/2005
Old Jul 30, 2005 | 04:33 PM
hybridsol's Avatar
Default Re: B16a3 Turbo help.... (LSvtec delsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec delsol &raquo;</TD></TR><TR><TD CLASS="quote">The other option is USDM b18c1 pistons which would give me 9.17:1(zealautoworks.com) Which would be the best combo for turbo.</TD></TR></TABLE>
Sounds like you already know the answer....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec delsol &raquo;</TD></TR><TR><TD CLASS="quote"> My goals are about 220hp. </TD></TR></TABLE>
Running 5psi?
I wouldn't turbocharge a stock bored block, but that's me.
Old Jul 30, 2005 | 05:15 PM
DC-4-Drew's Avatar
Default Re: B16a3 Turbo help.... (hybridsol)
I know that is low HP, but like you said it is a stock block, and I don't want to push it too far.......So is 9:1 the ideal compression ratio for turbo??
Old Jul 30, 2005 | 05:17 PM
DeadVet's Avatar
220 on a b16? Why not have a higher goal? Im making 276whp on 11psi and it runs like a dream no problems here.
Old Jul 30, 2005 | 05:45 PM
DC-4-Drew's Avatar
Default Re: B16a3 Turbo help.... (1TurboHatch)
are you running on stock cyl? I just want this to be as relyable as possible....
Old Jul 30, 2005 | 05:50 PM
DC-4-Drew's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridsol &raquo;</TD></TR><TR><TD CLASS="quote">"The other option is USDM b18c1 pistons which would give me 9.17:1(zealautoworks.com) Which would be the best combo for turbo."
I left the question mark out. that should have been a question and not a statement.
Old Jul 30, 2005 | 06:43 PM
DeadVet's Avatar
yes my b16 is all stock.
Old Jul 30, 2005 | 08:57 PM
Oyvind Ryeng's Avatar
A stock B16A will make 220 WHP and beg you for more.
Old Jul 30, 2005 | 09:11 PM
DC-4-Drew's Avatar
Default Re: B16a3 Turbo help.... (Oyvind Ryeng)
If I go w/Forged pistons and eagle rods, will I have a problem with the stock sleeves??
Old Jul 31, 2005 | 05:41 AM
DC-4-Drew's Avatar
b4 church bump.....
Old Jul 31, 2005 | 10:17 AM
300whpOrBust's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec delsol &raquo;</TD></TR><TR><TD CLASS="quote">If I go w/Forged pistons and eagle rods, will I have a problem with the stock sleeves??</TD></TR></TABLE>
no, the weakpoint of the b16 is the ringlands, they'll go before the rest of your bottom end gives out. With pistons and rods you should be fine for most reasonable goals. With only a 220 whp goal, you don't really need...anything if you want a bit more leeway you can lower the compression with a headgasket.
Old Jul 31, 2005 | 02:52 PM
b16sedan's Avatar
Care to elaborate on what you mean by "have a problem" with the sleeves?
thegeezerkid
Jun 14, 2008 10:56 PM
grappler
Jan 4, 2007 12:53 PM
effinnwackk
37
Apr 13, 2005 11:43 PM
850T5
28
Sep 9, 2004 07:34 AM
AzNjL427
12
Dec 19, 2003 10:58 PM
