b16a2 sleeves with mahle low compression pistons
are my stock sleeves in my b16a2 FRM???? do i need a special type of piston?? who is running stock sleeves in their b16 with aftermarket pistons, and any feedback on mahle pistons? my local engine rebuilder phoned and asked an engine rebuilder in regina as they've done a few boosted honda's that they use mahle pistons with mahle piston rings, i dont knwo if my stock sleeves are FRM or not for me to go with the gold series pistons by them that the rings are copatible with the FRM sleeves
Re: b16a2 sleeves with mahle low compression pistons (NJIN BUILDR)
the b series pistons from Mahle are not for FRM sleeves, they work well also, i made 460 on them in a b16, 81.5mm
Re: b16a2 sleeves with mahle low compression pistons (boosted92)
^^^^id check your crank first to see if its still withen spec with your bearing number stamped on block and crank.. so mnay miles it can wear it down some
ITR.#1446
07-22-2008 09:34 PM
hondaapi
04-07-2005 05:08 AM
