B16A2 IM vs. ITR IM?
Old Feb 13, 2004 | 09:45 PM
VinceVTEC's Avatar
Default B16A2 IM vs. ITR IM?
Would there be significant gains from swapping out the b16a2 intake manifold for a ITR intake manifold? This is for boosting at a moderate level of 8-10psi, and stock motor. Also, are there any differences between the ITR IM and Skunk2 IM? I know that the skunk2 has a model for gsrs that just bolt on, but is there a difference in their designs? or is it a straight copy.....
Thanks in advance!
Old Feb 14, 2004 | 07:05 AM
Naterror's Avatar
Default Re: B16A2 IM vs. ITR IM? (VinceVTEC)
the skunk2 manifold is based on the ITR, so I don't see any difference in performance. yes, its a difference over the stock b16. more mid and top end than the B16, but if your going boost I would go with the jg manifold.
Old Feb 14, 2004 | 08:22 AM
99B16Si's Avatar
i dyno tested the b16 vs skunk2 and gained 13whp a 2wtq at about 12-13psi. all the gains were above 6500rpm
Old Feb 14, 2004 | 05:49 PM
VinceVTEC's Avatar
Default Re: (99B16Si)
Cool. I don't think my setup needs the JG, since i'm only running a Greddy kit. Just wondering if i should replace the manifold while i swap my headgasket. Anymore opinions?
Old Feb 14, 2004 | 10:27 PM
99B16Si's Avatar
skunk2 all the way
Old Feb 14, 2004 | 10:40 PM
-iLLuZioN-B18C1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99B16Si &raquo;</TD></TR><TR><TD CLASS="quote">skunk2 all the way</TD></TR></TABLE>
ill 2nd the skunk2. its what im running
the jg is something i would get if i only ran my car
at the track. not sure how it is on the b16's, but on
gsr's, there is alot more midrange power from skunk2
compared to jg's manifold.
Old Feb 15, 2004 | 12:30 AM
Naterror's Avatar
Default Re: (VinceVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VinceVTEC &raquo;</TD></TR><TR><TD CLASS="quote">Cool. I don't think my setup needs the JG, since i'm only running a Greddy kit. Just wondering if i should replace the manifold while i swap my headgasket. Anymore opinions?</TD></TR></TABLE>thats cool then, I didn't know what size turbo you were going to run. but yes the skunk will be better and since your replacing the manifold I would use a hondata manifold gasket as well.
Old Feb 15, 2004 | 12:59 AM
SiBirdie's Avatar
Default Re: (Naterror)
I got the AEBS intake manifold for the b16. I heard it make more power then a skunk 2 one. I forgot, i saw it on the dyno somewhere.
Old Feb 15, 2004 | 07:42 AM
VinceVTEC's Avatar
Default Re: (SiBirdie)
You guys are all saying Skunk2. But did Skunk2 modify the ITR in anyway to make it flow better or something? or is it a straight copy?
Old Feb 16, 2004 | 08:21 PM
VinceVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VinceVTEC &raquo;</TD></TR><TR><TD CLASS="quote">You guys are all saying Skunk2. But did Skunk2 modify the ITR in anyway to make it flow better or something? or is it a straight copy?</TD></TR></TABLE>
Anyone?
Old Feb 16, 2004 | 08:28 PM
TurboJesse
Guest
Posts: n/a
just turn the boost up and get the power that way, its cheaper
Old Feb 16, 2004 | 08:29 PM
here ya go
https://honda-tech.com/zerothread?id=489676
https://honda-tech.com/zerothread?id=101456
https://honda-tech.com/zerothread?id=99406
read in there and youll find your answre.
Old Feb 17, 2004 | 05:45 AM
VinceVTEC's Avatar
Default Re: (-iLLuZioN-B18C1)
Thanks
LoooseGSR
Jun 27, 2007 06:15 PM
Twin-cam
Aug 5, 2004 08:31 AM
GReddySetGO
Nov 17, 2001 09:58 AM
Xerxes
Nov 10, 2001 04:10 PM
