B16a Turbo Setups
Old 10-24-2008 | 06:56 AM
  #551
GEN2 LS's Avatar
Default Re: B16a Turbo Setups (stanzione88)
^ i wanna see some in-car vids of your car!
Old 10-24-2008 | 12:32 PM
  #552
K7-1Ktrevor's Avatar
Default Re: B16a Turbo Setups (GEN2 LS)
I just dont get it? my stock single cam with junky ebay turbo kit did 2.2's all day long. but with my b16 I can't figure it out, and I have drag radials and a LSD.....
just need more seat time in the dual cam I suppose.
Old 10-24-2008 | 01:13 PM
  #553
BigZeke5's Avatar
Default Re: B16a Turbo Setups (K7-1Ktrevor)
D single slam's are known to have good torque. Maybe thats why you had a better 60' with the D then with the B. What were the specs on that D and your B now?
Old 10-25-2008 | 07:06 AM
  #554
KevronsEG's Avatar
Hey guys i had a B18c last year but found low compression in number 3 cly so i got a b16 bottom end and put that in for this year till i can build the gsr. So i hit the trck this past weekend. here is what i got with only two runs.
run one
2.1 60ft
8.5 1/8
88.21 mph
12.9 1/4
113.13 mph
run two
2.0 60ft
8.2 1/8
89.08 mph
12.5
113.91mph
i was super happy to be in the 12's with my 1.6 haha
JDM b16
Blox Intake Manifold
65mm TB
GSR Cams
AEBS Head Studs
GSR Tranny
ACT Clutch
Type R LSD
LoveFab SST
GT28RS with ATP T3 housing .63 a/r
38mm wastegate 10psi spring no boost controller
3.0 Down pipe, 3.0 exhaust
resonator, vibrant muffler
JRC 8in intercooler 2.5inlet/out
2.5 charge pipes greddy S BOV
1.75 dump tube under oil pan
780cc injectors
kevron
Modified by KevronsEG at 3:00 PM 10/25/2008
Old 10-25-2008 | 11:56 AM
  #555
Shaun Ek's Avatar
Default Re: B16a Turbo Setups (KevronsEG)
nice times for the set up
Old 10-25-2008 | 12:15 PM
  #556
Audiojb's Avatar
B16a2
Stock Bottom end
Omni Power Valvetrain
Skunk2 IM
RC440s
Garret t3/t4 .60 trim
Tial 38mm
Lovefab Ramhorn Manifold
Open DP
275 on 8-9lbs in a gutted eg
cams and more psi soon
Old 10-25-2008 | 10:12 PM
  #557
Z-TEC's Avatar
Default Re: (Audiojb)
Just finised reading this whole thread, im thinking of getting a turbo on mine. I want it to be a daily driver with 9psi. Something that wont hurt my pocket much. Any suggestions guys?
Old 10-30-2008 | 09:21 AM
  #558
pgpbubble's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KevronsEG &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys i had a B18c last year but found low compression in number 3 cly so i got a b16 bottom end and put that in for this year till i can build the gsr. So i hit the trck this past weekend. here is what i got with only two runs.
run one
2.1 60ft
8.5 1/8
88.21 mph
12.9 1/4
113.13 mph
run two
2.0 60ft
8.2 1/8
89.08 mph
12.5
113.91mph
JDM b16
65mm TB
GSR Cams
AEBS Head Studs
GSR Tranny
ACT Clutch
Type R LSD
LoveFab SST
780cc injectors
kevron
Modified by KevronsEG at 3:00 PM 10/25/2008</TD></TR></TABLE>
what chassis/weight was this in?
Old 10-30-2008 | 10:42 AM
  #559
slotec's Avatar
Default Re: B16a Turbo Setups (pgpbubble)
dynoing my coupe on high boost tomorrow
Old 10-30-2008 | 12:33 PM
  #560
Silva Bullit DC4's Avatar
Default Re: B16a Turbo Setups (slotec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slotec &raquo;</TD></TR><TR><TD CLASS="quote">dynoing my coupe on high boost tomorrow </TD></TR></TABLE>
Thats wusup Marcus, keep me posted on the number, bro. Are you gonna dyno at Adrenaline?
Old 11-01-2008 | 09:54 AM
  #561
KevronsEG's Avatar
Hey pgpbubble, The car was a 94 Civic cx with full interior, it's my DD. Weight after run was 2370 with me in it. I weigh in at 130-135.
Old 11-03-2008 | 07:16 AM
  #562
pgpbubble's Avatar
anyone with std bore/stroke with a 60-1?
Old 01-02-2009 | 07:18 PM
  #563
93CX's Avatar
bump for some new setups
Old 01-02-2009 | 09:15 PM
  #564
crxfreak1117's Avatar
my fully built b16 crx
Old 01-03-2009 | 12:55 AM
  #565
Civic89stdB16's Avatar
looks great. mine will be done by the end of febuary.
Old 01-04-2009 | 03:27 PM
  #566
hmetzner0's Avatar
I've been reading the forums on honda-tech for years but never took the time to become a memeber, i finally finished my car so i thought it would be a good time to join. Just wanted to post my set-up, can anyone explain the best way to post pictures.... thanks!
Old 01-04-2009 | 04:58 PM
  #567
Boosted Chemist's Avatar
Old 01-04-2009 | 08:11 PM
  #568
hmetzner0's Avatar
Nevermind i figured it out.
Old 01-04-2009 | 09:15 PM
  #569
cool pic from the other night
Old 01-16-2009 | 01:54 PM
  #570
93CX's Avatar
bump I know there are plenty more out there
Old 01-16-2009 | 05:03 PM
  #571
tegman23's Avatar
i had .5 over with std stroke with a 60-1
Old 01-17-2009 | 09:47 AM
  #572
pgpbubble's Avatar
Im starting to have problems with my setup.
Drag manifold, tial 38mm gate "big blue" spring. Without a dumptube off the gate it would build around 9.3psi max. I got a 1.5 mandrel bend dumptube installed, and the car shot right up to high 15lbs. I figured this should be normal as its running off the gate. I changed the spring to a "big red" and the car boosts the same amount. No change whatso-ever. It creeps up to 15lbs or so only in 3rd gear. Granted, its abour 15-20 Degree's outside.
The side port on the gate is right to the turbo nipple, I also moved it right to the vaccum log on the fire wall with no change. The Boost gauge reads off the vaccum log also.
Any ideas what can be wrong? the Diaphram does not appear to be torn or anything of that sort.
Old 01-17-2009 | 11:05 AM
  #573
tegman23's Avatar
Are you sure there isnt a rip in the vacum line? That happened to me before the line and a tiny crack in it from the heat and it was causing over boost issues
Old 01-18-2009 | 05:15 PM
  #574
pgpbubble's Avatar
I figured out that the car builds 5 LBS with NO WASTEGATE AT ALL!! so the manifold cannot flow the required CFM of the turbo basically...So now the problem is...how to fix it.
Old 01-18-2009 | 07:08 PM
  #575
marcj's Avatar
(don't mind the cut shroud.. it was for a different setup.)
Quick Reply: B16a Turbo Setups
