B16a turbo problem
I got my b16 turbo fired up and starts up no problem every time and idles amazing but when you go to give it a rev it starts sputtering bogging out and wants to die out I'm pretty sure it's the tps sensor I think it needs to be calibrated or maybe it's cause I got it used ? but what else could it be anyone know ?
You expect a turbo car to run on stock maps?
Get the car tuned properly before you blow it up. Don't try to drive it until it's tuned.
Time out, what injectors are you using that your car is idling just fine on stock maps? 2+2=6 ITT.
Get the car tuned properly before you blow it up. Don't try to drive it until it's tuned.Time out, what injectors are you using that your car is idling just fine on stock maps? 2+2=6 ITT.
So many much more relevant statements and questions, and you went with that one...If you worked on your priorities, your car would be in a much better state already.
thanks ! And I'm not sure if this is out of a b18a or a b18c does that also matter ?
But youve made EIGHT threads on basically the same thing, all in this forum, all this month. FIX SOMETHING, doooo something
B16a turbo problem
Boost_em1_
Getting spark and fuel but not starting!?
Boost_em1_
B16a turbo wont start back up
Boost_em1_
B16 wont get spark!
Boost_em1_
Will crome tune work on hondata s300 ?
Boost_em1_
B16A turbo base map tune !!
Boost_em1_
B16a turbo project
Boost_em1_
Turbo B16 civic trouble
Boost_em1_
B16a turbo problem
Boost_em1_
Boost_em1_
Boost_em1_
B16 wont get spark!
Boost_em1_
Boost_em1_
Boost_em1_
B16a turbo project
Boost_em1_
Boost_em1_
B16a turbo problem
Boost_em1_
Boost_em1_
Boost_em1_
B16 wont get spark!
Boost_em1_
Boost_em1_
Boost_em1_
B16a turbo project
Boost_em1_
Boost_em1_
B16a turbo problem
Boost_em1_
Boost_em1_
Boost_em1_
B16 wont get spark!
Boost_em1_
Boost_em1_
Boost_em1_
B16a turbo project
Boost_em1_
Boost_em1_
scotb16turbowannabee
Nov 16, 2004 05:43 AM
