B16a modification suggestions
Old Mar 1, 2016 | 10:58 AM
THC4's Avatar
Icon6 B16a modification suggestions
Hello, new to the forums, long time lurker.
I have a 90 crx si that I swapped a dohc zc in last year. Had sohc zc before. Engine has a few things wrong with it so I'm planning on turbo so I'm buying a swap.
My buddy has a complete b16a swap from his crx, axles, linkage, ecu, trans, motor mounts etc full swap.
Picking it up for 1200, which I think is a good price. Ok to the point.
I'm planning on going turbo route this summer in it but I need it to be reliable so I'm building the engine up before I put it in. I need reliability because this will be my dd, I have a dui and car has ignition interlock device... long story, wasn't even drinking.
I'm gonna list the current mods and I'm wondering if you guys can help me decide on which pistons, injectors, rods bearings and also recommend anything else I might need?
Currently the engine has:
Itr cams
Supertech valve seals, springs, retainers
Elderbrock intake manifold
Elderbrock 70mm throttle body
Chipped p28 ecu not sure what is on chip
Skunk 2 cam gears
Header
My goal power range is around 300hp after turbo
I'm semi-knowledgeable about this stuff, but it sounds like all these items means the head is already built, besides bearings, and I should be looking at building the bottom end while leaving head alone.
Now on bottom end I'm wondering what suggestions you guys can offer all I can think of are
Pistons, arp head studs, rods, and bearings.
Keep in mind I am going to be replacing all seals and gaskets and painting engine so I can eat my lunch on it.
Do you guys think that head setup can hold 300hp daily driver reliably, and what should I do to the bottom. If you guys think I can handle more hp SAFELY let me know. Thanks!
Old Mar 1, 2016 | 12:12 PM
TheShodan's Avatar
Moderator
Default Re: B16a modification suggestions
Itr cams
Skunk 2 cam gears
Header
Actually, If the engine had survived good compression and leak down tests, you don't need ANY of that stuff to make it to 300whp... Just good engine management ( no "chipped" ecus or bullshit hardware.. Get a good Hondata, or similar,) get a good reputable tuner, make sure you have a good radiator and hoses, good quality turbo components, (no eBay, CXRacing, or similar companies) you'll be fine.
All that other stuff you listed is optional.
Old Mar 1, 2016 | 12:56 PM
THC4's Avatar
I can get high quality turbo stuff. So how much hp can stock rods and pistons hold up to? Like I said I want to be trouble free, I'm prolly going to be beating on it a lot.
Old Mar 1, 2016 | 03:26 PM
motoxxxman's Avatar
Originally Posted by TheShodan
... good quality turbo components, (no eBay, CXRacing, or similar companies)...
what's wrong with CXRacing? Their FMIC's, couplers, t-bolt clamps, and piping are pretty good quality in my opinion. Not 1000hp quality, but plenty good enough for a 300hp setup (manifolds excluded, that should always be left to a name brand)
Old Mar 1, 2016 | 05:09 PM
805 Integra's Avatar
I'm not sue about cheap waste gates lasting along with some of the cheaper hardware that some kits provide(nuts and bolts) on misallanious items. I guess OP can decide. I just don't hear too many problems with the actual item when it's not knockoff. Healthy bottom end should be fine with a good tune. If the head has more than 15kon titanium retainers I'd take a good look at them for wear. Although the cams ain't that aggressive, titanium does tend to wear out more than oem and yes I have seen them snap when worn.
Old Mar 1, 2016 | 06:25 PM
TheShodan's Avatar
Moderator
I've had over 9psi pressure drops with their intercoolers, regardless of size, implosions of the endtanks, and other problems with their manifolds. And I'm not just talking Honda. Many in Canada like to use that stuff, thinking it was "300hp good"... Wrong
Piping is easily collapse-able.
I don't care if it's "300hp good" or "1000hp good".. Why waste your money, just to spend it again later?
So, no thanks.
Old Mar 1, 2016 | 06:26 PM
TheShodan's Avatar
Moderator
And I've seen and owned them for longer than 90K with no "snapping".
For daily driver, he's fine with the titanium, as long as with everything else, it's taken care of with good maintenance.
Old Mar 1, 2016 | 06:29 PM
TheShodan's Avatar
Moderator
about 350whp. No more. It's the rods/ringlands that go first. But 300whp is a cake-walk.. WHEN PROPERLY TUNED AND MANAGED.
All the more reason to make sure no matter whether or not you use "pistons/rods" to make sure that your tune is spot on, your management is spot on, and you get quality materials and components.
You plan to "beat on it," then plan ahead to prepare to "beat on it.". Be smart, take your time, and get the right components. And it will cost more than you originally plan.
Old Mar 1, 2016 | 07:25 PM
THC4's Avatar
Well sorry for lost hope guys. But I think I might be putting this money towards a new car so I can build this crx more this summer.
Old Mar 2, 2016 | 07:16 AM
TheShodan's Avatar
Moderator
Using your project as a daily car always has inherent risk. Good decision on your part.
Old Mar 4, 2016 | 07:37 AM
BoostAndBoobs's Avatar
Ha, I learned the hard way on that one.
Old Mar 5, 2016 | 11:37 AM
THC4's Avatar
Well... a buddy of mine that I traded turbo kit for wheels has decided to sale it back to me for rent money 175. So if I can sell my prelude this week it is back in action. I'd hate to do it because I really don't wanna dd my project but I mean this full b16 swap is the best deal I've seen ever. Also I can't find a good car for less than 3000. So b16a turbo project is in motion.
Old Mar 5, 2016 | 01:34 PM
THC4's Avatar
Jumped too soon. He sold the crx swap for a crv.
Old Mar 6, 2016 | 11:38 PM
motoxxxman's Avatar
So, no thanks.
I have a cxracing fmic 28x8x2.5, piping, couplers, and clamps in my car, in my Sig. Its all 8 years old now. Less than 1psi drop, temp efficiency is phenomenal, and zero issues since new. Just sayin
axtran
Apr 25, 2006 04:11 PM
MR CRX
14
Jun 22, 2002 08:09 AM
surfie71
Apr 2, 2002 02:08 AM
crxforum
Dec 30, 2001 05:26 AM
Jaysmy
10
Aug 18, 2001 12:49 PM
