b16a guys, i need your help
Old Jul 20, 2002 | 10:59 PM
PrecisionH23a's Avatar
Default b16a guys, i need your help
Set up: 94 hatch with 1st gen b16a motor. Ok guys, i am missing 2 rear motor mount bolts and i need honda part #'s for them. The bolts are pictured below inside of the red circles...
First pic... looking at the rear motor mount from the drivers wheel. Located below intake manifold...
2nd pic: close up of bolt needed, bottom 19mm bolt that bolts into the tranny.
3rd pic:another close up
4th pic: Looking from passenger side front wheel. Rear motor mount bolt. Bolts into the motor mount to the block. I have the bolt as you see pictured, but i need the nut that goes on the end. I thought there was a nut welded to the motor mount, but there isnt one. Did it fall off or is there a separate nut there?
5th pic: close up of bolt
6th pic: Opposite side of nut, where i am missing a nut or either the welded on nut on the motor mount came off.
Does anyone have part numbers for these or exact thread pitch and measurements of them? Also, is this motor mount supposed to have a nut welded onto it??? Thanks for all of your help...
Herminator
Welding / Fabrication
Oct 22, 2005 04:00 PM
RedTurboITR
Nov 28, 2004 04:27 PM
MeanD
Aug 22, 2004 03:39 PM
PrecisionH23a
Jul 24, 2002 01:11 PM
PrecisionH23a
Jul 20, 2002 11:10 PM
