B16 turbo, running lean at boost
Hey! As the topic says my b16 is running very lean when it starts to gain boost (3000rpms). I've tryed to adjust the fuel in the s300 but it dosen't change anything. Can it be a bad FPR or injectors? And btw, i'm getting CEL 16 (injector error).
Running, RC550cc, walbro fp, stock rail and regulator.
The car runs great on the lower revs.
br Jesper
br Jesper
The car is an 99 SI so i shouldn't need that resistor box? I've been using this injectors on my b16 SC without any problems :/
Correct, as long as the injectors are saturtated (high impedance) then you do not need a resistor box.
since the car is obd2, did you have to switch to obd1 style clips to install the injectors? if so check the wiring and make sure all the injectors are plugged in tightly
Unable to drive the car now, it's like someone is cuting the fuel when i push the throttle :/ Checked all wiring and measured the ohm on the injectors, everything is looking good. Can i have something wrong with my distributor?
if its coding 16 you have a wiring problem or burnt injectors or something. you need to get rid of that code 16 before even attempting to get into boost.
Changed out the injector clips to some new ones, also checked the fuel pressure (raised to 45psi). Still getting code 16 :/ Any more suggestions?
brokenojoke
Apr 16, 2006 11:42 AM
More suggestions?
