B16 supercharged running like shit
Old Jul 12, 2012 | 10:15 AM
98b16sc's Avatar
Icon2 B16 supercharged running like ****
I have a 98 civic with a b16 swap and a jackson supercharger it has a hondata ecu. i bought the car with a bad idle and i cleaned the idle air control valve. the car ran better for a few days but then the idle went back to being the way it was. now 2 months after buying the car its been acting up. if im driving down the street and just barely touch the accelerator it does nothing until i give it more gas and then it jerks itself, but i can see the vaccum gauge go down so my throttle body is opening like it should. i think its probably my throttle position sensor. and 2wice in the last 2 weeks its done this thing where it just dosent have any power and wont go over 4500rpm if i let it idle it dies on me i shut it off and clean the throttle body and it starts up just fine and goes back to normal. any sugestions???
Old Jul 12, 2012 | 10:20 AM
Dc4LsTeG's Avatar
EK9
Default Re: B16 supercharged running like ****
Cel? Is it tuned or on a basemap? Do you have a wideband?
Old Jul 12, 2012 | 12:00 PM
bigpunn421's Avatar
check out my threads. i had similar problems
Old Jul 12, 2012 | 01:59 PM
Veris's Avatar
That sounds like a TPS problem. Either wiring or the sensor itself.
Hook the hondata up to your computer and data log the TPS values to confirm.
Old Jul 12, 2012 | 07:37 PM
turbociv910's Avatar
take it to your closest tuner
Old Jul 12, 2012 | 11:28 PM
98b16sc's Avatar
its tuned and running hondata s300
98b16sc's Avatar
do i need special software to hook it up to my laptop?
Old Jul 12, 2012 | 11:34 PM
98b16sc's Avatar
i dont know if its a wideband or not. the air/ fuel ratio gauge seem too run lean most of the time tho specially at low rpm and idle
Old Jul 12, 2012 | 11:41 PM
Dc4LsTeG's Avatar
EK9
No just install it from the disc if you have it if not download it off hondata.
What brand is it? You don't know is its a wideband or narrowband?
Old Jul 13, 2012 | 04:07 AM
DDTECH's Avatar
Who tuned it..?
Old Jul 13, 2012 | 09:01 AM
seanjgsr438's Avatar
it could be a lot of things need more info.
Old Jul 13, 2012 | 09:33 AM
98b16sc's Avatar
i dont know what brand it is or if its wideband or narrowband. it was tuned at Revhard in Rock Island, IL just before i bought it. and what other info do you need? i really want to get this thing running good. note (the header has a leak at the colector but i didnt order one until i fix this first.
Old Jul 19, 2012 | 10:17 AM
98b16sc's Avatar
Replaced the tps this morning and seems to be running great again. Whats a good header for under 150 dollars? I saw this one online. http://item.mobileweb.ebay.com/viewi...id=06553730111
blazzer
18
Jan 12, 2014 01:18 PM
Honda_San
Aug 27, 2009 08:40 AM
davenport517
13
Apr 21, 2008 11:27 AM
wicca_eagle
10
Jul 20, 2005 12:39 AM
spaceman
Apr 19, 2004 08:48 PM
