B16 sleeved 85mm
Old Feb 10, 2007 | 12:23 AM
Garage786's Avatar
Default B16 sleeved 85mm
Hi everyone,
Ive tried search for this but nothing comes up, I just wanted to see what your views were on the above. Id like to put some 9.0 compresion pistons in there and run around 500whp. I Would have expected this wouold suit more na aplication, but im not to sure?
Any info would be appreciated...
Old Feb 10, 2007 | 12:46 AM
BoostedEG6's Avatar
Default Re: B16 sleeved 85mm (Garage786)
and what is your question?
Can you do it? yes but if something goes wrong there is no room for rebuild
Old Feb 10, 2007 | 04:09 AM
komat's Avatar
Default Re: B16 sleeved 85mm (BoostedEG6)
there be room for a rebuilt but for another turbo built probably not
Old Feb 10, 2007 | 04:30 AM
rmcdaniels's Avatar
I bored my sleeved B16 to 84mm, just in case anything happened. I had a boost controller problem at the track and melted the pistons a bit, requiring a rebuild and a bore to 84.5mm. I ran it at a bit over 400 WHP, which was as much as I wanted for a car that I mostly used on the street, but it could have made 500. I drove it for a few years until I sold it to somebody, last I heard he was still running it. Like others said, go a little smaller so you have a bit of room for error, you may need it.
Old Feb 10, 2007 | 06:22 AM
civicjdmb16a's Avatar
Default Re: B16 sleeved 85mm (rmcdaniels)
i have one check my sig not tuned on dyno yet. im going in a couple of weeks. and i think i have plenty of room to go on my sleeves. you can still go to a 85.5 or a 86mm.
TravisBiggie
Feb 11, 2014 03:19 PM
bowtieboy911
Mar 1, 2011 03:58 AM
blakh
Sep 5, 2007 03:24 PM
BLKCivicPorscheStyle*
Mar 9, 2005 03:30 AM
Mr. Vapor
Dec 15, 2002 07:36 AM
