b16 or gsr block?
Old Feb 15, 2009 | 02:48 PM
Milab21's Avatar
Default b16 or gsr block?
Im going to be boosting my 99 si, i am gonna just put the kit on the stock b16 for now but i want to build the bottom end, should i pull out the stock block and build it or pick up a gsr block and build that and put it in when its ready to go? I will be using the peakboost ftw kit and my goal is around 350whp. Parts im going to use so far is a chipped p28 ecu to get tuned on crome, exhaust, 650cc injectors, gsr cams, and the rest im still unsure about, any advice would be great, thanks.
Old Feb 15, 2009 | 02:53 PM
TheShodan's Avatar
Moderator
Default Re: b16 or gsr block?
either block can support 350whp when it is built. The difference is the amount of torque used. Though our honda engines are not torque happy at all under 2.5 litres, The more the stroke, the more the torque (in addition to appropriate bore). If its your first turbo car and you have a B-series engine, just use that to start off with, and don't over work yourself with the rest.
Old Feb 15, 2009 | 03:10 PM
JRSC01GS-R's Avatar
if I was in your situation, I would go ahead and boost the stock motor in the car and have fun with it for a while, in the meantime id build a simple cp piston and eagle rod gsr block on the side, that way u can still drive and enjoy the car and when u get boost hungry u can throw in the gsr block and crank up the boost
Old Feb 15, 2009 | 03:33 PM
1999siguy's Avatar
i am in exactly the same boat. I purchased a gsr block from a guy on craigslist for about 200 bucks. i was planning on running an N/A setup, but after calculating it out, the difference in price between ~200whp and ~450 was about $1000. so i talked to my tuner, and he said the gsr block was better because of the girdle about the mains, not to mention the extra 200cc's.
Old Feb 15, 2009 | 03:41 PM
EARLdaSQUIRREL's Avatar
official honda whore
boost the oem b16 block and build an gsr with ls crank and forged internals for when the stock block goes
Old Feb 15, 2009 | 05:11 PM
Milab21's Avatar
thanks for the replies, im gonna just boost the motor for now and build a block on the side. Is there any other block that i could benefit from or just a gsr block built? And anything to reccomend to go with my turbo set-up that would be useful. thanks
Old Feb 15, 2009 | 05:16 PM
xander1100's Avatar
Arp
Old Feb 15, 2009 | 05:19 PM
Joseph Davis's Avatar
Boost the stock motor for now. Throw it away if you are interested in building one, there is a big difference in powerband when you get away from the no stroke B16.
Old Feb 15, 2009 | 05:25 PM
Milab21's Avatar
sounds good, what are good websites that have deals on parts for motors and shortblocks? or info about how they build engines, prices, etc..
Old Feb 15, 2009 | 05:26 PM
Milab21's Avatar
i hear you on that, i was gonna go n/a with mine too but it wouldn't be worth it.
Old Feb 15, 2009 | 08:07 PM
TheShodan's Avatar
Moderator
Depends upon what you mean by worth it. Power isn't everything.. Though I am on the FI forum in which that seems to be the norm. Depends upon the purpose and use.
Old Feb 15, 2009 | 08:15 PM
nytosc's Avatar
From: New York in the summer, South Carolina in the winter
Exactly. and its cheaper in the long run to use the GSR block.
You can pickup a OBD1 GSR shortblock, sell the crank, pistons, rods, and oil cooler for 350, and assuming you got the shortblock for around 400 dollars, that means 50 into the block.
Buy a LS shortblock for 100 bucks, pull the crank, and sell the rods for 50, and block for 50.
50 dollar for your bottom end (of course you need rods/ pistons/ oil pump/ gaskets/ bearings ect) and now you dont have to worry about oil feed lines or any of that junk. When your ready, just bolt the B16 head on and have fun.
Old Feb 15, 2009 | 09:29 PM
black_EM1's Avatar
Community Builder
Community Influencer
Exactly what I did, it's a great idea.
Old Feb 16, 2009 | 02:48 AM
Death_to_Thieves's Avatar
IMO if you are going to do all that, just start off with an LS block to begin with. You don't NEED a girdle and you won;t have to worry about selling **** to make money back for buying **** that you aren't going to use. An LS block will more than handle what your goals are.
Old Feb 16, 2009 | 05:30 AM
I'd rather have a girdle for the long haul than not have a girdle. In the 400-600whp range the GSR bottom ends (or LS, sleeved B20, etc) statistically last longer.
It's cheaper to get an LS block and fit a GSR girdle to it than to buy a GSR engine and fit an LS crank to it. That being said, if you already have a GSR bottom end I wouldn't go to the ends of the earth to stuff an LS crank into it... 3mm bore gets you a lot more than a little over a mm of stroke.
Old Feb 16, 2009 | 12:06 PM
OP-If you have a GSR block already, use it. If not, you can buy an LS cheap, build it and push 350 with ease all day. You can push more if you want. I think as long as it is built correctly and you have a solid tune, it shouldnt be a problem . That's up to your tuner though. Buying 2 blocks and selling stuff etc. Just seems like more of a hassle than what its worth IMO. Just use what you have whether LS or GSR. Either will do the trick. Good luck.
Old Feb 16, 2009 | 12:49 PM
Milab21's Avatar
Thanks i like that idea a lot, who is a manufacturer that has reliable parts and etc for putting into the block (pistons, rods, etc...) And once i get the head on will that be a gsr with a b16 or a ls vtec sicne im using the ls crank?
Old Feb 16, 2009 | 01:45 PM
TheShodan's Avatar
Moderator
I'm trying to understand this question here. Could you elaborate please? If you could, include appropriate punctuation, we can understand it a bit better.
Old Feb 16, 2009 | 02:44 PM
Milab21's Avatar
Who is a manufacturer that has reliable parts and etc. for the block (pistons, rods, etc...)? And once i get the b16 head on the gsr block with the ls crank, will that be just a gsr with a b16 head, or will that be considered a ls vtec sicne im using the ls crank?
Old Feb 16, 2009 | 02:48 PM
JRSC01GS-R's Avatar
go with cp pistons and eagle rods, (just make sure to match your rods to your crank) and oem headgasket and bearings
as far as what to call it? its a gsr block with ls crank and b16 head so its not really a gsr any more, and its deff not a lsvtec cause it has a gsr block with oil passage for vtec cast into it so idk?
Old Feb 16, 2009 | 02:53 PM
Milab21's Avatar
Sounds good. Thanks, ill check it out.
Old Feb 16, 2009 | 04:17 PM
Bailhatch's Avatar
Here's what I did while I beat the life out of my B16 turbo for the last two years...
Old Feb 16, 2009 | 10:24 PM
black_EM1's Avatar
Community Builder
A motor, no more, no less. It would essentially be a PoorMan's R with an LS crank. No biggie. Call it a RichMan's LS if you care that much.
Old Feb 17, 2009 | 12:00 PM
1999siguy's Avatar
btw if you are going with a ls crank, be aware that the journels are larger than the gsr's.
Old Feb 17, 2009 | 01:05 PM
Milab21's Avatar
haha... it doesn't matter to me, I was just wondering.
