B16 EF with a FULL radiator??
Old Jun 22, 2006 | 06:58 PM
AaronJ's Avatar
Default B16 EF with a FULL radiator??
Do any of you ef guys out there have turbo setups with the stock rads?? I am putting on my kit next week and i want to know if i can get away with using it. If you can't use a full rad, I can get a eg half sized correct?
Old Jun 23, 2006 | 11:11 AM
91jdmhatchback's Avatar
Default Re: B16 EF with a FULL radiator?? (AaronJ)
yes you could use your full size but you would need to have the manifold made for a full size rad. It tucks the turbo close to the block, there is not alot of room so i would say your better of getting the half size...
Old Jun 23, 2006 | 12:27 PM
HiProfile's Avatar
Default Re: B16 EF with a FULL radiator?? (91jdmhatchback)
Most people just slap a manifold together with no regards for space restrictions. The EG rad can go in, but you still have issues, esp if it is an AC-compatable manifold. I'm going to shoehorn a teggy rad in soon, since my car tends to start overheating when I stop. It may be the bad HG or the fan blades needing to be reversed (still blowing towards rad), but I want a bit more capacity since I have AC.
Old Jun 23, 2006 | 01:25 PM
AaronJ's Avatar
Well i am using a log manifold, so i would assume that it will probably bring the turbo close to the block, i also don't have ac anymore
JDMmadness
Nov 7, 2010 04:52 PM
WhiteVX
Jun 10, 2009 04:35 AM
bigcivman09
Feb 23, 2009 06:09 PM
b18a-hatch
Jan 25, 2009 02:12 PM
Keith P
Aug 16, 2004 01:00 PM
