b16 Eagle rod bolt torque
Old Feb 21, 2006 | 07:22 AM
tommyj's Avatar
Default b16 Eagle rod bolt torque
I am assmebling my motor tonight. I need to know b16 torque for arp 2000 rod bolts with oil or assembly lube, I do not have the arp moly lube.
i serached and only found gsr specs.
Old Feb 21, 2006 | 02:43 PM
tommyj's Avatar
Default Re: b16 Eagle rod bolt torque (tommyj)
nobody??
Old Feb 21, 2006 | 02:45 PM
cobra2326's Avatar
Um, unless earl or some reputable engine builder tells you, I wouldnt trust just any response. Check the engine build article on evans-tuning, or call eagle.
Old Feb 21, 2006 | 02:51 PM
92cxturbo's Avatar
It depends on which rod bolts they are. If they are 3/8's then it's 45ft pounds.
Old Feb 21, 2006 | 07:27 PM
tommyj's Avatar
Default Re: b16 Eagle rod bolt torque (92cxturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92cxturbo &raquo;</TD></TR><TR><TD CLASS="quote">It depends on which rod bolts they are. If they are 3/8's then it's 45ft pounds.</TD></TR></TABLE>
thanks i appreciate it
Old Feb 21, 2006 | 08:55 PM
D@nnY's Avatar
3/8 42-45 ft lbs
5/16 26-28 ft lbs
b20vtech
Apr 20, 2007 08:51 AM
CA6VTEC
Dec 12, 2005 10:17 PM
2phast
Jun 25, 2005 08:41 PM
EK FLY
Dec 31, 2004 06:18 AM
nortrop
Aug 16, 2004 06:03 AM
