b16 built block with b18c1 head?
b16 block resleeved with RS machine sleeves
- ARP head studs
- 85mm bore
- arias piston 12:1 compression
- Eagle rods
- micropolished crank
- type R oil pump and water pump
- NEW GSR rod and main bearing and thrust washers
will that block work with my GSR Head? i am planning on changing compression to 9:1 for turbo.... what would the compression be with the gsr head? is it worth doing it or will I lose too much torque?
- ARP head studs
- 85mm bore
- Eagle rods
j me4door
Mar 10, 2009 12:31 PM
