b16 build up
Old Mar 2, 2005 | 06:41 PM
SpOoNisMyFriEnD's Avatar
Default b16 build up
i am looking at a civic hatch that has a b16. its relatively a stock motor.. the car is way to nice to pass up. i am a gsr motor fan, but this will have to do. what would be nesecary to get this car into the 11's. ls/vtec turbo setup? what will i have to do to it.
thank you man
Old Mar 3, 2005 | 07:29 AM
ERL Performance's Avatar
Default Re: b16 build up (pebblepusher101)
We can take your B16 and turn it into a B18c and with an LS crank we'll make it 2.0 liters. We do these blocks all day long. It's a track and street proven engine and very reasonable in price. Here are a couple of links for it.
http://www.erlperformance.com/...-.jpghttp://www.erlperformance.com/...t.jpg
We've had ours taken up to 900hp on 40psi and there were no leaks at all.One solid engine. Let me know if I can help!
Old Mar 3, 2005 | 07:54 AM
m R g S r's Avatar
Default Re: b16 build up (ERL Performance)
A b16 will never be a b18c, maybe it will have the same specs, but it won't "transform"
Anyway, if your gonna get all that work done to the block, why not just start out with a GSR block with a cracked sleeve or something....I kno I sold mine for $75 about a year ago....
And BTW...If you put on a big enough turbo, you can push that stock internal'ed b16 to about 300-330whp....That should be plenty to break you into low 12's or high 11's on slicks.....
Old Mar 3, 2005 | 08:26 AM
TurboJesse
Guest
Posts: n/a
Default Re: b16 build up (m R g S r)
You can easily run 11's with a stock b16. 250whp-300whp should put you there.
Old Mar 3, 2005 | 12:26 PM
thanx for all the replies guys....
Old Mar 3, 2005 | 12:43 PM
Rod.'s Avatar
just stick with b16 turbo and you can get your goals
look at nsxmatt
Old Mar 3, 2005 | 01:14 PM
turboEGhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pebblepusher101 &raquo;</TD></TR><TR><TD CLASS="quote">i am looking at a civic hatch that has a b16. its relatively a stock motor.. the car is way to nice to pass up. i am a gsr motor fan, but this will have to do. what would be nesecary to get this car into the 11's. ls/vtec turbo setup? what will i have to do to it.
thank you man</TD></TR></TABLE>
You're a GSR motor fan but a B16 will have to do, then you talk about an LS/VTEC setup? What in gods name are you talking about?
Old Mar 3, 2005 | 01:27 PM
m R g S r's Avatar
Default Re: b16 build up (Mpir3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 &raquo;</TD></TR><TR><TD CLASS="quote">You can easily run 11's with a stock b16. 250whp-300whp should put you there.</TD></TR></TABLE>
Sorry, I forgot he wass running a hatch. That's why I said higher whp numbers.
HondaTeKnology
54
Jan 4, 2008 08:16 PM
sohcvtec706
Mar 4, 2007 02:01 PM
Dark Ringleader
Jul 23, 2003 08:00 AM
