b16 on boost...lmk
Old Jul 8, 2009 | 10:53 AM
jo-jo123's Avatar
Default b16 on boost...lmk
Ok guys i dicited to boost my b16 on a eg...
but the thing is am doing it completely stock internals...
have yah guys had done this beforeand got some power i mean i seen it
but never got around to actually do it...so i need yah opinions and experiences
I was also wondering how much whp...yah think ill make and how manny psi i can push
doing it on the safe side....so yeah i was researching before i actually do it...
Old Jul 8, 2009 | 11:04 AM
Teglove2's Avatar
Default Re: b16 on boost...lmk
It'll take plenty of power. Do a compression check/leakdown test and confirm the health of the engine. You're going to have to install headstuds and I'd recommend a golden eagle(oem) headgasket then the turbo kit is all you have to worry about.
Its also a good idea to replace the oil pump before you boost it. I'd probably keep that engine under 300whp or 10psi whichever comes first. You could be anywhere from 250-300whp depending on what cams you go with and what turbo manifold/turbo setup. Good luck
Old Jul 8, 2009 | 11:27 AM
jo-jo123's Avatar
it has around..around 80k on the engine so its pretty healthy
Old Jul 8, 2009 | 11:39 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
go through our FAQ at the top of the forum. you will find the info you are looking for and more there.
eromezab
Engine Management and Tuning
Jan 27, 2014 08:34 AM
honda_mike
Oct 29, 2008 10:46 AM
Ratchback
Jan 13, 2006 12:06 PM
J-Spec VTEC
Jun 15, 2004 10:27 AM
nomotorsol
Jun 13, 2004 08:30 PM
