B16 turbo, did i lose compression??
Old 01-13-2006, 09:12 AM
Ratchback's Avatar
Default B16 turbo, did i lose compression??
Hey there i had a few quick questions. I have a 94eg with a b16 turbo on it. I was boosintg 8 psi until all of a dueen it was running a little choppy and next thing i know i hit turbo and the boost gauge goes up to 15psi!! so im like wtf so i pop the hood and realize that the tube that goes from the manual boost controller to the wastegate had just disconnected or came off somwehow but i have no idea how. I guess the zip tie was too loose and couldnt hold it on good.
Well anyway, i hooked it back up and it feels like its not spooling good and that im hearing more of the motor and less of the boost/pull. what do you think happened? thanks
aaron
Old 01-13-2006, 09:18 AM
Mr. Badwrench
boostedcivicsir's Avatar
Default Re: B16 turbo, did i lose compression?? (Ratchback)
if the engine is stock, do a compression test. odds are #4 has melted ring lands.
Old 01-13-2006, 10:54 AM
Ratchback's Avatar
Default Re: B16 turbo, did i lose compression?? (boostedcivicsir)
if it does have melted ringlands, how much will that cost to get fixed? and what exactly is involved ? thanks for the quick reply
aaron
Old 01-13-2006, 11:42 AM
XxRoCkMaNxNEOxX's Avatar
do a comp test. if the numbers are close together then u are ok
Old 01-13-2006, 12:06 PM
88crxhfb16's Avatar
you will have smoke coming from the valvecover breather, more than likely if its the ringlands
esurds
25
04-15-2010 05:33 AM
Christopherian1982
06-14-2008 10:57 PM
94hatchvx
11-05-2006 09:34 PM
nomotorsol
06-13-2004 08:30 PM
Smooth-GSR
07-13-2002 06:30 AM
Quick Reply: B16 turbo, did i lose compression??
