B16 or b18 boosted
If your building a daily driver,Go with the B16 turbo because you will have major traction problems but traction gets better with the lower stroke B16.Unless your gonna race at the track,Then go GSR because youll have slicks and it wont matter.Put it this way if you raced with a 350whp street tire B16 againsy a 600 whp GSR on street tires,You will kill the bigger motor since hell be spinning all 4 gears.
"if you want to make more power, don't, because you won't be able to put it to the ground"..
Invest a little in your suspension and some decent tires along with things like LSD and you have somewhat of a cure for your high hp issues. It doesn't matter HOW you slice it. FWD is going to have traction issues with much anything past 200whp on the streets. Thats just the way it is. From a higher mph roll though that 600hp car is going to chew the **** out of your 350whp B16. Thats all there is to it.
A stock LS or B20 will make good power. Don't assume you have to build something in order to make good power. There are many stock LS's in the 300whp range and some over if you check out the LS-T thread. B20's aren't bad engines either. Many people bitch about the sleeves but I think it has a lot to do with the tune and how far they are pushed. Advantage is LS and B20's are cheap as hell. If I could get away with it here in California I would run the B20. Instead I have a B18B since I have to play somewhat legally.
Umm, no, its not ALL in the tune, and im not sure why everyone says that.
Also, not everyone builds there motor so in most cases compression should matter.
I was just stating the facts, the dude can choose what he wants, but he might as well take the more logical route.
BigD, im not sure what your getting at, maybe you can explain whats horribly wrong in my post instead of posting something so bland that makes absolutely no sense what so ever...
yes there are some people out there that just buy an ebay turbo kit and slap it on their car and get an extra 20-30 HP out of it safely. anyone who is serious about their motor though builds the block. also the compression ratio between a b16/gsr/ls motor isnt all that much. b16s are 10.4:1, GSR is 10:1, and LS is 9.2:1. so if your going pure stock motor then the LS would be the most stable.
This theroy is lame.
Nice huge run on scentence/rant. Now keep feeling good with your light to light 20 foot races. I'll stick to my highway rolls.
https://honda-tech.com/forums/showth...ight=b16+turbo
refer to this post. ignore all the ignorant posts with no info backing them. the whole point is on a STREET CAR a b16 setup would be better. Darrell is right but he just doesnt have the info to back his argument. i watch 2 guys here in jax with 260-270 whp b16 eg hatches leave all sorts of cars behind. new gto's, 400whp supra, 410whp 300zxtt. think about it logically. street tires and basic suspension arent gonna handle high hp on fwd. if you wanna go the route of building a track car with full suspension and slick w/e thats fine go with the bigger motor. i personally love my 390whp b16. i get better traction than i did in my gsr at 347whp.
Well, in my opinion, building a high hp FWD WITHOUT doing suspension is just un-intelligent. You have half the puzzle, so yeah, its going to have setbacks. The higher hp/higher tq engine though is still going to be capable of accelerating quicker then the lower hp/lower tq engine given the same vehicle weight and gearing. Comparing a high hp FWD to something like a supra or a GTO is apples to oranges. Those cars weigh a good deal more, so they are going to take more hp/tq then a 2,300lbs little hatch to run the same times. I see the point that he is trying to make, but I think its not a very logical one. Why build something only to do it "half assed"? You see my point?
i definitely see your point but some people turbo there car and thats it. it really takes alot of work to get a high hp car to hook right. not many people on the street have the money to make it work. thats why everyone does highway rolls. dude here in jax had a 556whp gsr. it was very sick. hunted busas down on the highway. on the track even on slicks he was only in the high 12's though. building every aspect of a car can get really expensive thats why i like b16s. it takes alot less for the car to handle the power because of the low tq. of course the higher displacement setup would be ideal its just the $$$.
Use a b16 reason why i say a b16 because it has a shorter stroke then the gsr the gst has a long stroke and its puttin the engine to more stress with turbo also use a b16 tranny case with gsr gears reason why i say that because a b16 tranny is stronger then a gsr but gsr has longer gears....there u go jus gave u some good *** advice gl with ur build
99BlackHatchSiR
Apr 21, 2007 03:31 AM
