B series transmission internals interchangeable?
Old Jan 2, 2003 | 08:11 AM
Bnjmn's Avatar
Default B series transmission internals interchangeable?
Are the internals from B series cable trannies interchangeable? More specifically 92-93 cable transmissions and 92+ hydros. Do they only differ in the hydro/cable actuation?
Thanks
Ben
Old Jan 2, 2003 | 10:00 AM
dustin's Avatar
Default Re: B series transmission internals interchangeable? (Bnjmn)
They are internally much different. Honda changed the way the bearings and shafts are layed out among some other things. I know because I tried swapping '94 LS transmission internals into a '91 LS transmission housing and it really did not work.
Old Jan 2, 2003 | 10:26 AM
rioninja's Avatar
Well supposedly the 92+ cable trans do have the same upgraded internals as the hydros, but i personally havnt split one.
Old Jan 2, 2003 | 08:35 PM
tony1's Avatar
Default Re: B series transmission internals interchangeable? (RioNinja)
90-91 are totally different, but 92-00 are the same...
Old Jan 3, 2003 | 06:20 AM
Bnjmn's Avatar
Default Re: B series transmission internals interchangeable? (tony1)
Ok...why do Quaife and Kaaz have different LSD part #'s for the '94+ Integra vs. the 92+ B16/B17 trannies?
Thanks
Ben
Old Jan 3, 2003 | 06:37 AM
tony1's Avatar
All LS and B16's use the same diff. Type R and GSR use the same diff. The difference between the two is the inner diameter of the ring gear.
Old Jan 3, 2003 | 08:01 AM
Bnjmn's Avatar
Radio shack, thank you very much.....
You just saved me bunch of cash because now I can switch in a new gear set to my 92-93 LS case and get a cable/hydro adapter without having to buy a whole hydro tranny.
Thanks again
Ben
C-West Civic
Transmission & Drivetrain
Feb 27, 2015 07:00 PM
blackeg
Dec 22, 2014 10:28 AM
gRim06
Sep 6, 2010 04:15 PM
damn_import_culture
Dec 17, 2006 10:12 AM
Absentmind
Jun 19, 2004 12:12 PM
