b and d series turbo q
Old Oct 28, 2005 | 04:45 PM
dtown_racer's Avatar
B A N N E D
Default b and d series turbo q
how big of a difference is there between the distance of the exhaust ports on a b series head compared to a d series head? i have a b series turbo mani layin around but wanna use it on my d. can i just cut the flange off the d series mani, then cut the one off the turbo mani, and then weld the d one on? will it line up? any help is appreciated. thanks
Old Oct 29, 2005 | 06:33 AM
B A N N E D
Default Re: b and d series turbo q (dtown_racer)
Old Oct 29, 2005 | 06:50 AM
RacerXI's Avatar
I'm not exactly sure how work extensive it is, but there have been a few people to use a d-series greddy manifold on a b-series head. IIRC, they were just enlarging the bolt holes. The "search" is down, but hopefully that'll give you a start.
Old Oct 29, 2005 | 07:07 AM
dnbruut's Avatar
Default Re: b and d series turbo q (RacerXI)
buy a d series gasket and then you will be able to compare the 2
Old Oct 29, 2005 | 07:45 AM
B A N N E D
Default Re: b and d series turbo q (dnbruut)
i cant believe i didnt think of that ...doh!
Old Oct 29, 2005 | 08:08 AM
nota-eg's Avatar
Man, that is so much work. I had a B series manifold that was welded onto a turbo. At the time I was going to do a B swap, but decided not to, so I bought one of the cheap D series manifolds (DX or whatever).
I cut off the flange and was working on getting it smooth enough to weld it onto the B manifold. Turned out to be too much work with the limited tools I had so I had the B manifold cut to pieces w/ a plasma cutter and bolted the turbo to a D series manifold that I bought.
JeremyL
Dec 21, 2009 04:02 PM
LoganWade03
Nov 3, 2005 09:20 AM
Turbo'dMex-A-Keen
Jun 11, 2003 02:12 PM
JeremyL
Dec 16, 2002 07:08 PM
