Axle question
Old May 31, 2009 | 04:22 PM
StolenTeg's Avatar
Default Axle question
I have a 95 CX Hatch with a B18B1 motor, recently the diff on the LS tranny went so i bought a 94 GSR tranny.
I got the tranny and everything fit fine except the passenger side axle, it is too short. Im using 98 Integra LS axle from the car i got the b18b1 from.
As far as i know i thought that all integra axle are the same except ITR 36mm axle?
Has anyone run into this problem? do i need a GSR passenger side axle?
Did some search and GSR and LS axle are the same part number, why wont it fit -.-
Old May 31, 2009 | 09:52 PM
2ndchirp's Avatar
Default Re: Axle question
I have a 99gsr trans in my 95LS.. no problems with axles...could it be bacuse its a civic hatch?
Old Jun 1, 2009 | 11:03 AM
StolenTeg's Avatar
I dont know what is wrong with this thing, the axle is the right one. I measure a LS and a GSR axle and they are the same.
Old Jun 1, 2009 | 11:23 AM
redlinetuning's Avatar
No, they are not different lengths. Problem with axles is that over time, the bearings/grease doesn't work as well with normal wear&tear. The inner cv joint can also retract/extend like the outer, but if the inner joint doesn't extend far enough, then it may seem like the axle is too short.
I had this happen on both my axles, ended up getting a reman'd axle, looked at them side by side, and look the same, but the new one fit fine.
I opened up an old axle I didn't need anymore and found the grease was thicker than the new grease that came with the rebuild kits.
Old Jun 1, 2009 | 12:15 PM
StolenTeg's Avatar
Here are some pics showing the problem
With the lower balljoint in the LCA, the axle is way too short.
If i have the axle sit flush with the hub, it would be impossible to get the lower balljoint into the LCA
Edit: Picture are taken with axle fully seated in the tranny
Old Jun 1, 2009 | 12:23 PM
Yes, I remember those problems. Save yourself the trouble and go get a warrantied shaft from Autozone/Napa/parts store.
Josh7x
Feb 11, 2011 10:56 AM
StolenTeg
Jun 1, 2009 01:04 PM
stockb18c
Transmission & Drivetrain
Apr 5, 2009 07:50 PM
xingyun
Nov 30, 2008 02:06 PM
crxmex
Jul 24, 2006 05:39 PM
