Axle pops out after new setup
Old Jan 24, 2007 | 06:09 PM
eg crunkmonster's Avatar
Default Axle pops out after new setup
Well my axle pops out of the tranny on the passenger side after hard pulls. It happens every once in a while. Ive tried like 4-5 different axles already and no the snap ring is not stuck in the diff. I even swapped trannys and it still does it. It never did it before with my old LS turbo setup at 231whp. Now with my lsvtec and like 420 whp, it started popping out. Checked the mounts and nothing is ripped. I also added rear motor inserts since my last motor. I also have full integra front brakes/spindles, control arms, and sway bar
Old Jan 25, 2007 | 07:16 PM
Default Re: Axle pops out after new setup (eg crunkmonster)
help?
pix for views
Old Jan 25, 2007 | 07:23 PM
aaroboost's Avatar
interesting....
someone help this guy i know that would drive me crazy
Old Jan 25, 2007 | 07:26 PM
Tippyman's Avatar
Default Re: (aaroboost)
What chassis/mount kit?
The mount kit could be placing the engine too far to one side or something and it's making the axle stretch.
Old Jan 25, 2007 | 07:47 PM
Default Re: (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">What chassis/mount kit?
The mount kit could be placing the engine too far to one side or something and it's making the axle stretch.</TD></TR></TABLE>
1995 Civic hatch. I was thinking the rear mount might be the problem. something is making the axle too short i tihnk
Old Jan 25, 2007 | 08:42 PM
Tippyman's Avatar
Default Re: (eg crunkmonster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg crunkmonster &raquo;</TD></TR><TR><TD CLASS="quote">something is making the axle too short i tihnk</TD></TR></TABLE>
Yeah. Does the boot look stretched?
Old Jan 26, 2007 | 04:36 AM
Yeah. Does the boot look stretched?</TD></TR></TABLE>
i was testing that and it seems theres too much play, so it seems like something is causing the distance between the hub and tranny to be too long
Old Jan 28, 2007 | 06:20 AM
bump
Old Jan 28, 2007 | 09:41 AM
DontBlink's Avatar
try opening up the c clip on the end of axle a little bit more.
Old Jan 28, 2007 | 10:50 PM
crxhoutx's Avatar
Default <<
at the end of the axle that goes into the tranny there is a ring that is designed to keep the axle in place. Check to make sure its still there or might need replacing. Hope this helps, Benny
edit: just read the post before me, that should do the trick
Old Jan 29, 2007 | 04:54 AM
mike1114's Avatar
Default Re: << (crxhoutx)
fyi.....I got an axle a vatozone after about 10 minutes of driving it popped out. I figured they gave me the wrong one (maybe an LS, not GSR) so i took it back and got another one. Same **** happened.
I found out that vatozone had the wrong part numbers on the axles, they tagged the LS as GSR.
Once I got the right axle, no problems.
Old Jan 29, 2007 | 05:07 AM
GrinderGuy2's Avatar
Default Re: << (mike1114)
you should sue them for 20 hours of labor
flatblack-h22
Transmission & Drivetrain
Apr 12, 2013 06:11 AM
SlickC95
May 23, 2012 09:35 PM
makeustruggle
Dec 13, 2008 09:20 PM
99JdmDc2
Jul 26, 2007 09:09 PM
92jdmhatch
Oct 24, 2006 02:10 PM
