AVC-R wiring diagram for 2000 Integra?
Me and Matt (SilverLS2000) just reinstalled the AVC-R back on my integra. Anyway, we d/l the apexi' us version of diagram and it only has 96-98 Integra. I figured that should be it and wired it up. Somehow..the RPM is not reading it correct (reads between 300~1500rpm)...Does anyone the problem?
Jeff-
Jeff-
Guest
Posts: n/a
Re: AVC-R wiring diagram for 2000 Integra? (Corporal-Jeff)
there are different wiring diagarams depending on what year car your installing it on ie: 94-95 (obd1) integra wiring diagram will not work for and 96+ integra (obd2) im guessing thats why its not reading rpm, i would also suggest you uninstall it asap and dont run your car with it until you can find a proper diagram.
Re: AVC-R wiring diagram for 2000 Integra? (dc2on10lbs)
erf? i thought i explained this enough..
I have a 2000 car and the most updated "manual" which is available in the apexi-usa.com site is not lasted. I'm asking if anyone know which diagram to use.
Jeff-
Jeff-
Just checking but did you check this
http://www.apexi-usa.com/produ...m.pdf
look at H4 it is for 99-00 integras and civics the same one i used
Re: AVC-R wiring diagram for 2000 Integra? (DeepSi)
Jeff....I'm checking out the diagrams now...I think we switched injetor signal and rpm....the two versions of the H4 diagram are different....come by tomorrow, we'll fix it when we do the oil pan gasket.
BigMikeyStyle247
10-22-2003 08:26 AM
