Attn: Hondata Users! Need some help with fuel...
Old Nov 27, 2001 | 09:53 AM
_Shadow_'s Avatar
New User
Default Attn: Hondata Users! Need some help with fuel...
Alright what have you done to your fuel system besides larger injectors?
Old Nov 27, 2001 | 10:35 AM
randomwalk101's Avatar
Default Re: Attn: Hondata Users! Need some help with fuel... (_Shadow_)
nothing..that's all u need. just modify the fuel map to deliver the correct amount.
Old Nov 27, 2001 | 10:50 AM
adam's Avatar
Walbro intank 255lph fuel pump
Old Nov 27, 2001 | 10:55 AM
Markaccord95's Avatar
regulator
Old Nov 27, 2001 | 10:59 AM
adam's Avatar
Default Re: Attn: Hondata Users! Need some help with fuel... (Markaccord95)
yeah, figured that was a given
btw, nice sig
Old Nov 27, 2001 | 11:07 AM
TurboITR's Avatar
FPR
Fuel Filter
-10 braided line up -8 back
500gph pump
lots of earls fittings
[Modified by TurboITR, 3:14 PM 11/27/2001]
Old Nov 27, 2001 | 11:21 AM
DamonBoost's Avatar
New User
Default Re: Attn: Hondata Users! Need some help with fuel... (TurboITR)
I am running the vortech fmu and i am getting ready to get the hondata.. I need to get an adjustable fpr like the aem right??
Old Nov 27, 2001 | 12:20 PM
cyan1de's Avatar
Default Re: Attn: Hondata Users! Need some help with fuel... (Damon501)
i believe the Vortech FPR will work with hondata. i hear it is adjustable like the AEM.
Old Nov 27, 2001 | 12:22 PM
DamonBoost's Avatar
New User
Default Re: Attn: Hondata Users! Need some help with fuel... (cyan1de)
But then would I have to change disk as opposed to turning a screw??
Old Nov 27, 2001 | 12:27 PM
VTC_CiViC's Avatar
FMU and FPR are two different things. With a Hondata you don't need a rising rate FMU anymore since your car can now add fuel according to boost pressure electronicaly. An adjustable FPR on the other hand will let you fine tune your static fuel pressure to maintain acceptable levels through out the rev range, though in reality, if you're got a Hondata with larger injectors and a good pump, you shouldn't need it for anything other than maybe to reduce a little pressure since the Hondata will take care of the fuel needs from there.
Old Nov 27, 2001 | 02:10 PM
_Shadow_'s Avatar
New User
Default Re: Attn: Hondata Users! Need some help with fuel... (VTC_CiViC)
OK I'll just get a Walbro intank fuel pump. Any objections?? If so, whats a good and reliable fuel pump?
Old Nov 27, 2001 | 02:22 PM
VTC_CiViC's Avatar
If you're going standalone, an intank Walbro should be more than enough..
Old Nov 27, 2001 | 03:02 PM
philo's Avatar
you dont really want a rising rate regulator like, JR or Vortech unit.
To be honest i think the stock fuel system w/ 440's can deliver enough fuel for most applications.
I run at 42psi and made 230hp@8psi (JRSC) at about 80% duty cycle.
Old Nov 27, 2001 | 03:30 PM
DamonBoost's Avatar
New User
Default Re: Attn: Hondata Users! Need some help with fuel... (philo)
So with 550s and hondata I wont need to get a fuel pressure regulator? I can just run the stock one??
bboyoxygen
Dec 28, 2004 12:21 PM
adictionbass
Aug 12, 2004 07:44 PM
threatcon13
Oct 28, 2003 09:13 PM
PrecisionH23a
Aug 28, 2002 12:32 PM
ZERO COOL
Jul 28, 2002 12:22 PM
