Assitance Request :Identification of Precision Turbo SC50
Old Mar 31, 2017 | 11:19 AM
Jianshatch's Avatar
Default Assitance Request :Identification of Precision Turbo SC50
got this turbo for a good deal in a kit 360 thrust bearing new seals etc please tell me what turbo it is so I can research if it can meet my goals pics below , I figures it's precision sold to me as a garret 60 trim
Old Mar 31, 2017 | 11:26 AM
TheShodan's Avatar
Moderator
Default Re: Name that turbo
Check The FAQs. It has that answer for you.
Make sure you get Compressor / Turbine wheel measurements in millimeters, which will require housing removal.
Find any data plates, tags or inscriptions on the inside of the compressor outlet and turbine housing to help.
Understand how turbochargers are measured. Read all of this. Also in the FAQs
Turbo Tech 101 - Tech-Knowledge - Import Tuner Magazine
It's the 1st listing on the FAQs.
https://honda-tech.com/forums/forced.../#post11973386
Old Apr 1, 2017 | 12:24 PM
Jianshatch's Avatar
2.09 inducer and 2.99 exducer stamped cce50 on inside with reasearch seems to me a precession sc50 with your expierenced opinion would this be sufficient enough for my 500whp goal on a h22 built with meth injection
Old Apr 1, 2017 | 01:13 PM
TheShodan's Avatar
Moderator
No. It would not reach that power level, regardless of fuel type used
Old Apr 3, 2017 | 11:08 AM
ESP.net's Avatar
Default re: Assitance Request :Identification of Precision Turbo SC50
Be a good street turbo at low boost but yes too small... sc61 is where the life starts for the H and bigger power goals.
boostedBLUfg2
Jul 5, 2011 10:00 PM
theEGkid
Sep 22, 2005 10:44 AM
seanjohn81
Jul 8, 2003 01:00 PM
Acura_I-RS
Apr 13, 2003 06:42 PM
