askin the boost god for some advice
Old Apr 2, 2005 | 11:12 AM
itr1143's Avatar
Default askin the boost god for some advice
ok here is the question.i am building a new turbo motor,here is the set up-b18c block with darton sleves and erl super deck 1,crower 4340 rods,je pistons,pro drive oil pump,ferrea valves-springs-retainers,stock integra type r cams and crank,sfp mani,sfp 2.5 down pipe, tial wastegate and blowoff valve,pression sc61 turbo,aem ems with gm boost silonoid.what i want to know is what spring i need for the wastegate if i intend on running 400 to 420 hp???
Old Apr 2, 2005 | 11:20 AM
Evanmb44's Avatar
Default Re: askin the boost god for some advice (itr1143)
figure out what the minimum psi that you want to run is. if you ever want to turn down the boost, the lowest setting you could go would be that of the spring.
so say someone wants to run 10psi, but they may want to drop it down to 7psi or so for just normal driving. in this case, you would want a 7psi spring. with a boost controller you can always turn up the boost, but you cant turn the boost below the spring setting of the wastegate. just keep that in mind when choosing a spring
vg7z
Sep 20, 2006 08:27 PM
Harassing Herbs
Mar 1, 2004 08:31 PM
yusoslo
Jul 12, 2003 08:01 PM
shingles
Jan 24, 2003 01:58 AM
wonny
May 30, 2002 03:18 PM
