ARP stud retorque question
Old Mar 25, 2003 | 11:50 AM
B18EG6's Avatar
Default ARP stud retorque question
When you retorque ARP headstuds, do you back them off at all or just tighten them back down?
If you are replacing the headgasket, later down the road will you have to retighten them again or are they already stretched?
thank you
Sebastian
Old Mar 25, 2003 | 11:55 AM
BoostedSi's Avatar
Default Re: ARP stud retorque question (B18EG6)
You dont back them down at all...you just torque them more(i think 10ft/lbs more..)
Also i think you need to retorque them again after you change headgaskets.
Old Mar 25, 2003 | 11:58 AM
b18bturbo's Avatar
all you would have to do is retorque to spec thats all there no need to do anything else they have stretched after you use them but i sually buy new a new set everytime we do a build up 115 is cheap for some hardware that will make sure you head doesnt lift
Old Mar 25, 2003 | 04:55 PM
B18EG6's Avatar
Default Re: ARP stud retorque question (b18bturbo)
Well they have been on for about... 500 miles, thats all. I dont have the money to buy new ones right now so Im going to stick with the ones i got.
after i replace the headgasket, I will torque them down to spec....than like 250 or so miles later retorque them? how should I schedule the retorque?
Old Mar 25, 2003 | 05:20 PM
boosted hybrid's Avatar
After 10 heat cycles you retorque them again. This is when the car comes up to full heat, then cools down again. 10x like that. You dont loosen then tighten, you just torque them down more. You'll find that they back off around 5-10ft-lbs.
Old Mar 25, 2003 | 11:53 PM
B18EG6's Avatar
Default Re: ARP stud retorque question (boosted hybrid)
Boosted- Thanks, that helps me a lot. Appreciated.
Old Mar 7, 2006 | 10:26 AM
KiddEng's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid &raquo;</TD></TR><TR><TD CLASS="quote">After 10 heat cycles you retorque them again. This is when the car comes up to full heat, then cools down again. 10x like that. You dont loosen then tighten, you just torque them down more. You'll find that they back off around 5-10ft-lbs.</TD></TR></TABLE>
Bringing this back from the dead...since i cannot find a concrete answer.
i get the idea that it should be retorqued if they are BRAND NEW, but what about re-used ones? Cannot find the difinitive answer on retorqueing the re-used headstuds.
thanks
Old Mar 7, 2006 | 10:41 AM
Finland's Avatar
Default Re: ARP stud retorque question (KiddEng)
Assuming that the used studs have never been over torqued, then you should treat them just like new studs. Once studs, or bolts have been torqued beyond their rating, they lose their tensile properties.
Honda Civic (2001 - 2005)
16
Oct 9, 2010 11:44 PM
89vwfox
Apr 1, 2010 03:46 PM
totsie7944
Jun 20, 2008 10:15 AM
k-series
12
Jan 19, 2006 08:52 PM
RICE POLICE SIP
Mar 6, 2003 11:04 AM
