ARP Headstud washers...
Old Apr 25, 2007 | 12:51 AM
crazyimport's Avatar
Default ARP Headstud washers...
I lost one of these damn things. Can i just go to my local home depot and find a washer thats close/same to the others and it should be ok??
Any one else done this, what did you do
Thanks
Old Apr 25, 2007 | 01:37 AM
liam821's Avatar
25 Year Member
Default Re: ARP Headstud washers... (crazyimport)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyimport &raquo;</TD></TR><TR><TD CLASS="quote">I lost one of these damn things. Can i just go to my local home depot and find a washer thats close/same to the others and it should be ok??
Thanks</TD></TR></TABLE>
No - you cant do that. Washers at home depot will crush differently then the other washers in the motor and could cause a head bolt getting loose.
Call ARP at 800.826.3045 or visit http://www.arp-bolts.com/
You can buy the washer by itself, will only cost you a few bucks.
liam
Old Apr 25, 2007 | 07:58 AM
HiProfile's Avatar
Default Re: ARP Headstud washers... (liam821)
I'd actually call up Lightning Motorsports, they hooked me up twice with individual ARP parts I needed. They are well-priced and ship fast. Otherwise get it from the horse's mouth.
Old Apr 25, 2007 | 08:21 AM
Running925's Avatar
I had the same problem on a built motor. Replaced it with a stainless washer that i had laying around and it's been fine for well over a year.
take that for what it's worth, i'm not recommendng it but it's worked for me.
Old Apr 25, 2007 | 08:39 AM
turbodohcsi's Avatar
i used a washer off a factory head stud once... had no problems
Old Apr 25, 2007 | 11:13 AM
Mikey3000's Avatar
ARP washers for headstuds are ground flat as ***** so the load of the nut is directed perpendicular to the bolted surface. the washers from home depot are ground using gay methods.
Old Apr 25, 2007 | 11:15 AM
building boost's Avatar
most machine shops have these laying around. when i lost two i went to the machine shop and he gave me 2.
Old Apr 25, 2007 | 01:08 PM
B18EG6's Avatar
Default Re: ARP Headstud washers... (Mikey3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 &raquo;</TD></TR><TR><TD CLASS="quote">ARP washers for headstuds are ground flat as ***** so the load of the nut is directed perpendicular to the bolted surface. the washers from home depot are ground using gay methods.</TD></TR></TABLE>
Just out of curiosity - why did my friend's set of ARP studs come with spherical washers? We got new ones cause he ended up losing one fo the washers, but I was always curious why the washers were spherical when the nut's flange was flat?
B20_EG8
Oct 4, 2007 08:09 AM
rice a roni
21
Apr 17, 2007 09:23 AM
vtekthis
Oct 1, 2006 12:50 PM
eg6cusco10pt
10
Sep 23, 2004 05:39 AM
9200RPM
May 14, 2003 07:55 PM
