ARP Head studs/bolts
Old Apr 26, 2003 | 12:10 PM
B18PoweredCivic's Avatar
Default ARP Head studs/bolts
Are there two different kinds for B series motors...I see that theres two different sets of headstuds.. some for b18c1 and c5 and others for b18b and b18a etc...Whats the deal?...Are they the same thing?...What would i use for LS Vtec?
Old Apr 26, 2003 | 03:43 PM
Foozball26's Avatar
Default Re: ARP Head studs/bolts (B18PoweredCivic)
yes there are two different sets, the heads are different.
for an LS/VTEC you use the kit for whatever head you have.
Main difference is the B18C studs are all the same length while the LS block has 2 longer studs in the middle
Old Apr 26, 2003 | 04:15 PM
ebp 99 si's Avatar
Default Re: ARP Head studs/bolts (foozball-26)
i'm gonna be using a b18c block with a b16 head in the near future
which ones should i use?
Old Apr 26, 2003 | 04:50 PM
speeddave's Avatar
Default Re: ARP Head studs/bolts (ebp 99 si)
i did a bit of searching and it seems like the b16 studs are too short for the ls/vtec. everything i read in the archive's says that you are supposed to use the gsr ones when using either the b16 or the b18c1 head. i do not know for sure though, so if anybody could confirm this that would be cool.
Old Apr 26, 2003 | 04:56 PM
b18bturbo's Avatar
Default Re: ARP Head studs/bolts (speeddave)
on poormans type r setups b18c block and b16a head you need the 5303 vtec head studs b18c
Old Apr 26, 2003 | 05:19 PM
speeddave's Avatar
Default Re: ARP Head studs/bolts (b18bturbo)
is it the same for b18a bottom end b16a head? thanks
Old Apr 26, 2003 | 05:20 PM
b18bturbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speeddave &raquo;</TD></TR><TR><TD CLASS="quote">is it the same for b18a bottom end b16a head? thanks</TD></TR></TABLE>
on ls vtec use the studs that are for the head
Old Apr 26, 2003 | 05:34 PM
speeddave's Avatar
thanks!
projectef
20
Mar 5, 2022 08:47 PM
dai-18t
Sep 18, 2009 07:25 AM
Dancing is Forbidden
Jun 4, 2003 12:20 AM
sparkz
Apr 23, 2002 09:17 AM
SoloSol
Jan 9, 2002 04:38 PM
