Catch Can Mounting Ideas......Critique Mine
Old May 12, 2004 | 11:14 AM
ladysman's Avatar
Default Catch Can Mounting Ideas......Critique Mine
Guys,
I am looking for advice on where the hell I am going to put my catch can. I am going to post up my idea so let me know what you think.
My engine bay is completely full and this was where I was thinking to mount it. This is just above my MSD box and clears the hood no problem.
Now, the plan was to just take a 1" wide piece of aluminum (somewhat thick to hold well) and mount it straight against the wheel well. So it will be squeezed in between the battery and the wheel well as seen here
Wheel well
I would then drill 2 holes in the wheel well putting the bolt through the wheel well first keep it as flat as possible so the tires doesn't rub (or does very little).
So when mounted, it will look like this:
Thoughts? Other Ideas?
Thanks in advance.
Old May 12, 2004 | 12:50 PM
Cruiser G's Avatar
Default Re: Catch Can Mounting Ideas......Critique Mine (ladysman)
I think pretty much wherever you can make it fit and be functional is fine. That looks like a good spot
Old May 12, 2004 | 12:52 PM
Mr. Softee's Avatar
dont put it in until the motor is back in...
Old May 12, 2004 | 12:54 PM
ladysman's Avatar
Default Re: Catch Can Mounting Ideas......Critique Mine (94goldjungsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">dont put it in until the motor is back in... </TD></TR></TABLE>
You mean put the motor in then install? Why?
Old May 12, 2004 | 12:57 PM
FredoSP's Avatar
Are you going to use the drain back feature? If so then the T has to be higher than the brass block fitting.
Here's mine, I had to cut 2 L brackets, Im not using the drain back feature but I might change my mind.
Old May 12, 2004 | 12:58 PM
Mr. Softee's Avatar
Default Re: Catch Can Mounting Ideas......Critique Mine (FredoSP)
reason why i suggest to do it later is because whenever I've put motors in, I need all the space I can get. I always seem to be squeezing it in hardcore.
Old May 12, 2004 | 12:59 PM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">reason why i suggest to do it later is because whenever I've put motors in, I need all the space I can get. I always seem to be squeezing it in hardcore.</TD></TR></TABLE>
Ah, Gotcha.
Fredo, I like where you put yours. Have you had any issues? Did you mount it directly to the frame? Got any more closeup pics?
Edit, just read what you did. My bad. Got any real closeups though.
Old May 12, 2004 | 01:01 PM
ladysman's Avatar
I guess my next question is
Should I be using the drain back feature? Is having it better?
ALso, is mounting it higher better?
Old May 12, 2004 | 03:03 PM
dirtySOHC's's Avatar
you have yours exactly where i got mine....works out great. i wish i had a pic....sorry
Old May 12, 2004 | 06:36 PM
ladysman's Avatar
Default Re: Catch Can Mounting Ideas......Critique Mine (dirtySOHC's)
Up for the night owls. Bedtime for me.
Old May 12, 2004 | 07:16 PM
boostismycrack's Avatar
E-thug
ladysman, thats where mine is going, I don't see any problems.
Old May 13, 2004 | 05:45 AM
ladysman's Avatar
Default Re: Catch Can Mounting Ideas......Critique Mine (boostismycrack)
Thanks guys. I plan on working on this next week.
If anyone has any other suggestions, be my guest.
Old May 13, 2004 | 05:54 AM
dasher's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman &raquo;</TD></TR><TR><TD CLASS="quote">I guess my next question is
ALso, is mounting it higher better?</TD></TR></TABLE>
yes , use the drainback... i route it top a bung in my oilpan...
the higher the better for the drainback ... your location is fine ... I mount mine where the Harness plugs connect .. there are two 10 mm bolts located exactly the correct distance apart for the moroso.,.. they allow me to bolt it down like the catchcan was made for my car with absolutely 0 modification!!!
Old May 13, 2004 | 05:56 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Catch Can Mounting Ideas......Critique Mine (dasher)
why cant I see your pics ladysman? I can see fredo's but not yours.
Old May 13, 2004 | 06:02 AM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dasher &raquo;</TD></TR><TR><TD CLASS="quote">
the higher the better for the drainback ... your location is fine ... I mount mine where the Harness plugs connect .. there are two 10 mm bolts located exactly the correct distance apart for the moroso.,.. they allow me to bolt it down like the catchcan was made for my car with absolutely 0 modification!!!</TD></TR></TABLE>
Man, if you could send me pics I would really appreciate it. My email is in my profile. Or just post them here.
Art, I have no idea. Anyone else having an issue seeing my pics? I see them just fine.
Old May 13, 2004 | 06:05 AM
RobbieG35's Avatar
12 Years Strong
Art, I have no idea. Anyone else having an issue seeing my pics? I see them just fine.</TD></TR></TABLE>
I can't see them either
Old May 13, 2004 | 06:23 AM
ladysman's Avatar
Default Re: Catch Can Mounting Ideas......Critique Mine (HybridHatch88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridHatch88 &raquo;</TD></TR><TR><TD CLASS="quote">
I can't see them either</TD></TR></TABLE>
Y0, server was down. Should be up now guys.
Old May 14, 2004 | 12:03 AM
Arturbo's Avatar
Better than steak
25 Year Member
It looks good where its at now. Just make sure they side fittings are above the fittings in the block.
Old May 14, 2004 | 06:08 AM
PM-Performance's Avatar
Old May 14, 2004 | 06:51 AM
Blue-Civic-Hybrid's Avatar
Loved
Default Re: Catch Can Mounting Ideas......Critique Mine (itr206)
Just a question about that oil catch can, is that the Endyn one with e drain back feature? I am wondering what kind of baffling did you use inside the can or does it already come pre-baffled?
I am currently running open atmosphere on my engine setup and I am wondering if it would be beneficial for me to run the Endyn can on my JRSC'd motor...
Old May 14, 2004 | 06:55 AM
ladysman's Avatar
Default Re: Catch Can Mounting Ideas......Critique Mine (Blue-Civic-Hybrid)
That is the Endyn setup.
Old May 14, 2004 | 06:57 AM
i have the Endyne set up . its baffeled inside. Its just a Moroso can with all the Hardware really.
Old May 14, 2004 | 06:59 AM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">i have the Endyne set up . its baffeled inside. Its just a Moroso can with all the Hardware really. </TD></TR></TABLE>
Exactly. It's "Endyn" by the way.
Thanks for the pic. I am going to play with it next week since I am a bachelor for 5 days.
Old May 14, 2004 | 07:05 AM
sorry , lol.
must be nice , i wish i had that feeling even for 1day, lol.
Old May 14, 2004 | 07:59 AM
Loved
Thanks for the reply, so has this catch can been proven to be an actual working can compared to the ones that are for the "bling" effect. I saw it on the Endyn site and have been wondering to get it for my setup.
Also, just a question on how you set up the can, will one of the lines be from the valve cover breather? Or should I just get a little K&N filter on the valve cover?
