arias pistons
Old Jul 30, 2008 | 11:46 AM
  #26
X-Mazda 3 Racer's Avatar
Default Re: (0bd1_Kanobe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0bd1_Kanobe &raquo;</TD></TR><TR><TD CLASS="quote">I heard Arias Sucked because of the alloy used for this Piston is very soft and expands and retracts more than a CP or Wiseco would! </TD></TR></TABLE>
Sorry, but that was just the most un-technical and totally false statement I have heard in a long time. No getting defensive, but if you are going to try to make a point, be sure it's a valid one...
Your experience on the other hand is different. That is totally your preference. If Wiseco works better for you, then by all means use them. All I was saying is that the materials of pistons do not vary from manufacturer to manufacturer and I wanted to make sure people know that!!!
Old Jul 30, 2008 | 03:52 PM
  #27
Golden Eagle's Avatar
Default Re: (X-Mazda 3 Racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X-Mazda 3 Racer &raquo;</TD></TR><TR><TD CLASS="quote">other racers like......
All the GM ProFWD cars!
Ed Bergenholtz!
Bisi
all use ARIAS!
0bd1_Kanobe had more misinformation in his first post than I have seen in a long time. ALL PISTON MANUFACTURERS USE THE SAME MATERIAL!!! It's either 4032 or 2618 depending on the application. Hell, most get their forgings from the same place as well, and their coatings... So to say that it's material is just plain ignorant, sorry. Go do your homework...
Your experience on the other hand is different. That is totally your preference. If Wiseco works better for you, then by all means use them. All I was saying is that the materials of pistons do not vary from manufacturer to manufacturer and I wanted to make sure people know that!!! </TD></TR></TABLE> we use arias pistons in most of our builds never had 1 problem with them here
Old Feb 3, 2010 | 04:30 PM
  #28
evildc2/ef's Avatar
New User
Default Re: arias pistons
i got some arias pistons and they arnt even close to what the ptw is supposed to be. arias says ptw is .035 and i measured .050.... ive never had so much problems with a piston company before.
Old Feb 3, 2010 | 04:50 PM
  #29
purpleh22's Avatar
Older thread.
I'm using Arias on my H22 with zero problems - 520 whp and 12K mi. Checked ptw during build an it was right on. I heard that Arias had their own ring land spacing and that only their rings could be used? - if that is an issue.
Old Feb 4, 2010 | 04:01 AM
  #30
Turbo-LS's Avatar
Arias Pistos are top notch. very durable and will take alot of abuse. But just like any other piston company if not tuned properly then they will fail the same as a cp or weisco of je. Id say the only dissadvantage is they are a tad heavier than most BUT i find that to be better as its a more durable solid construction IMO. ive also run cp's and loved them. currently running je pistons because i got a slammin deal on them and they've held up just fine as well. there all good if used correctly
mitchell_2kSiR
Jul 29, 2008 08:28 AM
FuNkDrSpOt
Jul 29, 2006 12:21 PM
JLHDOHC
Apr 24, 2006 06:17 PM
EITCP
Nov 1, 2005 09:48 AM
AshlandSi
Oct 26, 2001 04:01 PM
