Arias or JE???
Old Dec 13, 2001 | 08:28 AM
BowSeR's Avatar
New User
Default Arias or JE???
im planning to build my motor soon and just wanted to know which is a better piston. cause i know arias has there new forging i believe with no silicone in the piston
Old Dec 13, 2001 | 08:31 AM
ForcedAccord's Avatar
Texas B*tch!
Default Re: Arias or JE??? (BowSeR)
JE
Old Dec 13, 2001 | 08:32 AM
TurboSedan's Avatar
New User
Default Re: Arias or JE??? (ForcedAccord)
I agree with ForcedAccord, JE.
Old Dec 13, 2001 | 08:40 AM
D-Man's Avatar
Arias or JE? id say whichever you find cheaper cause both are good pistons and chances are that something else will fail before an Arias or JE piston reaches its limit.
Old Dec 13, 2001 | 08:48 AM
rtype11's Avatar
Default Re: Arias or JE??? (D-Man)
that is the most logical response
Old Dec 13, 2001 | 09:27 AM
GSRacer's Avatar
New User
Default Re: Arias or JE??? (ekb18c)
i got je
Old Dec 13, 2001 | 10:47 AM
jamal-188's Avatar
Default Re: Arias or JE??? (GSRacer)
I agree w/ above. They are both very good pistons and most likely yuo will not reach the limit of what they can take.
Old Dec 13, 2001 | 10:50 AM
Rob03Pro5's Avatar
Default Re: Arias or JE??? (jamal-188)
I'm not too sure, but I've heard that Arias have less silicon content than JE.. so they will have more piston slap when you start the car cold. Like I said, its just something I've heard. As you can see in my sig, I'm a JE guy.
Old Dec 13, 2001 | 11:30 AM
BlwnBlue's Avatar
Default Re: Arias or JE??? (Rob92SC)
I think you've got it backwards..the JE gives more piston slap on cold start up because of the HIGH silicone content..
Old Dec 13, 2001 | 11:48 AM
Ray's Avatar
Ray
New User
Default Re: Arias or JE??? (BlwnBlue)
Arias offers different levels of silicon content. The Arias race pistons use the same alloy as JE
Old Dec 13, 2001 | 11:52 AM
TurboTypeR98's Avatar
New User
no, actually I believe he has it correct...
Old Dec 13, 2001 | 12:48 PM
SCREWD's Avatar
THESE ARE JE
Old Dec 13, 2001 | 12:56 PM
Ray's Avatar
Ray
New User
Default Re: Arias or JE??? (SCREWD)
The sleeves couldnt handle it, not the pistons. Those pistons look kinda high cr too(it's a B20turbo) with bad tuning.
Old Dec 13, 2001 | 01:16 PM
jinxproof99's Avatar
New User
nice sleeve.
the je's are nice though. thats what i have.
Old Dec 13, 2001 | 04:31 PM
SCREWD's Avatar
Default Re: Arias or JE??? (Ray)
Poo. Ray, I was just reinforcing what he stated about other parts failing.
Old Dec 13, 2001 | 05:26 PM
JJ-Built's Avatar
i have that happened to me once. i had JE pistons and they were fine, just nice 3" line crack on the sleeve that is all.
when something breaks it is because of the ( driver/owner) ERROR not because of a bad parts.
if you want cheap piston's stick with stock and just lower your static compression via a head gasket as long as the fuel and timing are tuned right you will be fine.
i have seen stock internals GSR motor with head gasket to lower the compression and are running 11's so spend your money else where........like paying your credit card debts.
Old Dec 13, 2001 | 06:39 PM
MisterB's Avatar
Default Re: Arias or JE??? (jjgotboost)
I have had better experience with Arias...their costumer service is great and turn around time is good for custom applications... I doubt you will be able to tell the difference between the two pistons, so go with the better price and you should be fine.
Old Dec 14, 2001 | 05:03 AM
Rob03Pro5's Avatar
You sure there?
E Town DSM
Jan 31, 2014 01:02 PM
Stealthmode Performance
Jan 19, 2012 09:58 PM
s2kkid
Nov 24, 2004 04:38 AM
boostedinteg03
Apr 15, 2003 12:06 PM
