APEXi turbo kit
Old Dec 9, 2001 | 07:51 AM
piscorpio's Avatar
Default APEXi turbo kit
Ive been searching around for info and experience with this kit on a D16, but to no avail. Does anyone run this kit? Ive read some good things about it in SCC, but no one seems to use this kit, opting instead for the GReddy, is this a pricing issue or something else? Also, I have a 00 Civic (APEXi's kit is 92-95), so would this kit be easily adapted in the same way the GReddy kit can be? Thanks for any help you guys can give me, all info/details are appreciated.
Old Dec 9, 2001 | 08:24 AM
AshlandSi's Avatar
Default Re: APEXi turbo kit (piscorpio)
The Apexi kit looks really nice, and uses a ball-bearing IHI turbo. And the intercooler for the kit is huge. Too big, really.
Old Dec 9, 2001 | 08:30 AM
piscorpio's Avatar
Default Re: APEXi turbo kit (AshlandSi)
Any idea what the IHI turbo is exactly? What size is it, etc.? Thanks AshlandSi, love the sig.
Old Dec 9, 2001 | 11:43 AM
DA666's Avatar
it is nice but custom will prob equal more power!!!! oh yeah fmic is huge....!
Old Dec 9, 2001 | 03:26 PM
liam821's Avatar
25 Year Member
they say it will support 250hp..so its like a small 16g in size. Larger then the greddy turbo but smaller then a t3/t4.
liam
Old Dec 9, 2001 | 06:54 PM
TurboInteg95's Avatar
I agree, go custom. teh apex manifold looks like something out of the eighties.
Old Dec 9, 2001 | 07:00 PM
Gmedalion's Avatar
Default Re: APEXi turbo kit (TurboInteg95)
My friend has it in his build D16 and it pulls but he's still working out some kinks.
Old Dec 9, 2001 | 07:06 PM
maxim's Avatar
Default Re: APEXi turbo kit (Gmedalion)
Have you checked http://www.optauto.com they have an Apexi Kit. I believe it's just the manifold,turbo, and tubing though. Don't know about fuel pump, wastegate, and NO intercooler.
[Modified by maxim, 11:09 PM 12/9/2001]
Old Dec 9, 2001 | 07:08 PM
D-Man's Avatar
the turbo is small in the apexi kit as compared to a rev hard or drag kit
Old Dec 9, 2001 | 07:37 PM
SpoonCivic's Avatar
New User
Default Re: APEXi turbo kit (liam821)
the greddy..atleast on the DOHC VTEC motors is 18g....
Old Dec 9, 2001 | 08:01 PM
EG8R's Avatar
Default Re: APEXi turbo kit (SpoonCivic)
18,000?? Wha?
Old Dec 9, 2001 | 11:08 PM
Smashback's Avatar
He's not comparing it to a Greddy 1.8 kit. Just a "small" TD05-16G.
Old Dec 10, 2001 | 08:39 AM
AshlandSi's Avatar
It may not be "pretty" like some of the tubular manifolds, but this will not crack.
[Modified by AshlandSi, 9:49 AM 12/10/2001]
Old Dec 10, 2001 | 08:41 AM
DR. ON POINT's Avatar
Banned
You, sir, are an idiot. This is probably the best possible manifold you can get for a honda:
y do u always say u sir are an idiot..........i dont like that manifold.....am i an idiot because i dont like a manifold?
Old Dec 10, 2001 | 08:44 AM
AshlandSi's Avatar
I'd much rather have a bulletproof manifold like this over some pretty-boy tubular joint that cracks every other month. Not to mention it clears A/C.
Old Dec 10, 2001 | 09:46 AM
Gmedalion's Avatar
Here's some pics of my friends Apexi turbocharged civic.
Old Dec 10, 2001 | 10:00 AM
BLKMamba's Avatar
BMW Güdentyte
25 Year Member
That intercooler is sweet!!!
Old Dec 10, 2001 | 11:39 AM
lucas569's Avatar
Default Re: APEXi turbo kit (booster)
what? that manifold looks sweet,very oem'ish looking. you et that bad boy coated and it would be be even nicer.
if i had the sohc THIS WOULD be the kit I would buy.
Old Dec 10, 2001 | 12:55 PM
piscorpio's Avatar
Thanks for all the responses guys, Ive been having a hard time getting any kind of feedback on this kit...seems the popular choices always come up. (GReddy, Drag, F-Max, etc.)
I dont give a rats *** about looks, Im all about performance right now. As far as how much performance, Im not trying to build a 300+ hp monster either. I just want a little more zip for my daily driver and minimal lag. 200 hp to the wheels sounds good to me, if you must put a number on it. I have relatively modest goals I suppose.
My final question though, is it easily adjusted to a 96+ SOHC Civic? Im assuming it shouldnt be too difficult, but Im not sure if there will be fuel management issues (OBDI vs. OBDII...does it even come with a "little black box" like the GReddy kits?)
[Modified by piscorpio, 9:59 PM 12/10/2001]
Old Dec 10, 2001 | 01:05 PM
AshlandSI, before I completely destroy you in an argument, how is that the best possible manifold you can get for a Honda. Because it wont crack? Do you know anything about making a turbo manifold? Have you ever made one? How do you know it wont crack, it's made out of cast iron, it WILL crack. I'm glad I saw on points reply before you got to change it so I wouldnt see you call me an idiot. The Apex manifold is far, very far, from the best possible manifold you can get for a Honda.
Old Dec 10, 2001 | 01:15 PM
PROFILES2000's Avatar
the apexi kit is awflly nice too bad its got a small turbo but nice lookin front mount
Old Dec 10, 2001 | 01:50 PM
PureTeg420's Avatar
Default Re: APEXi turbo kit (PROFILE GSR)
earlier this season at the track there was a guy with an Si who had modified the apexi kit to fit on his car, or at least some of the apexi kit. Well anyways he said his manifold cracked, and apexi sent him a new one. So yes they do crack, but apexi will probably send you another if it's a defect. BTW this guy was running very low 15's but i never asked how much psi he was shovin through the motor
Old Dec 10, 2001 | 07:46 PM
lucas569's Avatar
Default Re: APEXi turbo kit (PureTeg420)
the apexi kit should be easy to slap on a 6th gen civic,hell ive seen the greddy sohc cam kit modded to fit the 6th gen civic,crx's even 6th gen si's.
the kit is very basic, i think it only comes w/ turbo,piping,manifold,dp,clamps hoses,etc... the ic,pump are "upgrades" but apexi "highly" reccommends them,duh!
anyhow does anyone have the measurements of the ic?
its weird cause you can buy an apexi sylvia core AND HAVE THE ENDTANKS WELDED on for around $550 but the apexicivic ic costs $750+ ??
makes no sense...
Old Dec 10, 2001 | 08:00 PM
maxim's Avatar
Default Re: APEXi turbo kit (On Point)
What's wrong with the manifold? Just because it doesn't look pretty doesn't mean it will function properly. In fact, I think it's quite the contrary.
Old Dec 10, 2001 | 10:09 PM
Default Re: APEXi turbo kit (maxim)
I never said the manifold was gay I just said that it looked like something from the 80's. the 4-into a box design reminds me of old toyota headers and stuff. For best results the gases should at least be pointed towards the inlet of the turbo with some sort of collector. With the Apex manifold they're going to kind of swirl around inside the box until they finally find they're way into the turbo. It is fine for a street car, it will get the job done. But calling it the best turbo manifold for a Honda is just plain incorrect.
