anything else i should add?
Old Dec 31, 2001 | 01:15 PM
93B17A's Avatar
Default anything else i should add?
srp 9:1 pistons
eagle rods
stainless valves
quaife lsd
STR blockguard
clutchmasters stage III clutch
AEM plug-n-play
drag gen II kit
boost and EGT gauges
440cc injectors
AEM fuel pressure reg
MSD coil and cap
cam gears and pullies
flexlite fans
3 inch exhaust
I have allmost everything i am just waiting on pistons, rods, and the AEM plug n play. If there is anything else i should add for reliability and such, please post ...... oh and i plan to run 10 psi daily 15 for a race
Old Dec 31, 2001 | 01:19 PM
cyan1de's Avatar
Default Re: anything else i should add? (93B17A)
fuel pump?
Old Dec 31, 2001 | 01:23 PM
jinxproof99's Avatar
New User
spring/retainers
toss the stage 3 and go with the stage 4 clutch.
[Modified by jinxproof99, 5:24 PM 12/31/2001]
Old Dec 31, 2001 | 01:24 PM
93B17A's Avatar
Default Re: anything else i should add? (cyan1de)
yeah i'm still trying to figure out what i should run as a pump. i have done the search and i still not sure if i should run intank or inline, high pressure or high volume.......its very mind boggleing, but this is my 1st turbo car so i wanna do it right thats why i'm here
Old Dec 31, 2001 | 01:27 PM
93B17A's Avatar
Default Re: anything else i should add? (jinxproof99)
springs and retainers......... yeah i forgot about that any paticular recommendations?
Old Dec 31, 2001 | 01:28 PM
New User
i use the crowers.
Old Dec 31, 2001 | 01:36 PM
MatT3T4's Avatar
Reliability? How about engine management...! DFI, Motec, AEM, Power FC...something...otherwise all the money you just spent is pointless...
BAH! GOD DAMMIT! Nevermind, I just re-read your post, and you already have it. Good for you! Most people totally forget! Peace
[Modified by MatT3T4, 2:37 PM 12/31/2001]
Old Dec 31, 2001 | 01:39 PM
93B17A's Avatar
so if i do springs, retainers, and valves .......... i should do the valve guides right? if so are the bronze valve guides a good choice?
oh yeah in reguarding valve springs should i go with the dual springs or single?
[Modified by 93B17A, 5:44 PM 12/31/2001]
Old Dec 31, 2001 | 03:31 PM
HXMan's Avatar
Make sure you get some good tuning done. That will go a looooonnnnggg way.
Old Dec 31, 2001 | 06:48 PM
Aahj's Avatar
drag gen II kit
I was just wondering. Is there any particular reason why you chose the Drag gen II kit over the III. I mean, you have spent enough money as it is, why not go all the way!
other than that, it looks damn good. I wish I had that much money!
good luck,
aj
Old Dec 31, 2001 | 06:50 PM
Turbo00's Avatar
New User
Default Re: anything else i should add? (ajn)
get the jun springs with crower retainers and u might as well sleeve your block if your going to invest all that money u might as well do it right from the start but thats just a thought
[Modified by Turbo00, 3:51 AM 1/1/2002]
Old Jan 1, 2002 | 09:53 AM
ForcedAccord's Avatar
Texas B*tch!
drag gen II kit
There is hardly any difference between a Drag Gen II or Drag Gen III. It's just like one part, I don't even know if there is a price variance. Also, there aren't Gen III kits for every application.
[Modified by ForcedAccord, 6:54 PM 1/1/2002]
Old Jan 1, 2002 | 10:25 AM
Anthony K's Avatar
New User
Default Re: anything else i should add? (ForcedAccord)
Tial wastegate?
Old Jan 1, 2002 | 12:59 PM
93B17A's Avatar
well cause i bought the drag kit in july for a 93 gsr........... i really had no choice plus back then i want a/c , but now the skys the limit
a tial wastegate is going in the summer after i get everything running good cause i allready have a wastegate......even though its junk and ugly it should due for a month or two
how about ignition should i get an msd 6 ignition? ..................or should i do nothing cause i'm getting a standalone thanx
[Modified by 93B17A, 5:03 PM 1/1/2002]
[Modified by 93B17A, 5:04 PM 1/1/2002]
Old Jan 1, 2002 | 03:31 PM
threatcon13's Avatar
New User
i think u should make TIAL a top priority...I didnt and detonation occured due to boost spikes.... a Tial and Hondata 2b, RC 440s, and 1:1 fpr are included in my new setup. Just my two cents.
Old Jan 1, 2002 | 03:33 PM
New User
Default Re: anything else i should add? (turbo01gsr)
oh yea...what about an air/fuel meter? maybe split second..i dont really kno but i heard autometers arent too accurate.
Old Jan 1, 2002 | 03:53 PM
DIRep972's Avatar
Smarter than you
"not a bad way to spend 10k dollars"
Old Jan 1, 2002 | 06:26 PM
93B17A's Avatar
Default Re: anything else i should add? (DIRep972)
yeah tell me about it
isn't air/fuel monitered by the standalone?
Zero Turbo
11
Feb 26, 2008 04:22 PM
Zero Turbo
Aug 17, 2007 04:17 PM
mrkal
Jan 8, 2007 04:56 AM
obd1
Sep 19, 2002 05:03 PM
