Anyone's setup actually run perfectly?
Old Jan 19, 2003 | 04:45 AM
SoulSurfer's Avatar
Default Anyone's setup actually run perfectly?
Okay I'm getting very discouraged reading this forum because all I see is people having problems with their turbos. Is there even ANYONE here who has no problems?
I plan on getting a second car for those exciting times when my car is down but right now I'm in the process of a move and that takes money. I'm thinking I should just wait to do my install when I can afford the beater.
Old Jan 19, 2003 | 05:07 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: Anyone's setup actually run perfectly? (LSDelSol)
mine does. it runs perfect, no problems at all, except one, and it has nothing to do with it being turbo. i have a slight oil leak at either my crank seal or my rear balance shaft housing. either way, it could have happened regardless of wether the car was turbo or not. now when i get a standalone, i might run into some tuning problems until i get to my tuner. but other than that, everything is great
Old Jan 19, 2003 | 06:08 AM
shingles's Avatar
I think trying to judge the success of turbo's based on the forum is not a good idea. Typically people only post because they have a problem and are trying to get help.
If things work, people typically don't post about it.
-S
Old Jan 19, 2003 | 06:11 AM
SoulSurfer's Avatar
Default Re: Anyone's setup actually run perfectly? (shingles)
That's why I'm asking.
Old Jan 19, 2003 | 07:03 AM
scooter's Avatar
My custom setup runs perfect, no problems at all. Been turbo since Sept. 02.
scott
Old Jan 19, 2003 | 07:27 AM
rjardy's Avatar
Default Re: Anyone's setup actually run perfectly? (scooter)
you get out what you put into it Ben, dont worry itll be fine.
Rob
Old Jan 19, 2003 | 08:00 AM
hypa's Avatar
It's just a matter of tuning your setup properly and doing the routine maintenance when you go boost. At low boost my setup ran well. When I went standalone, and screwed around with the settings is when my car started to be a pain. That's the way you learn though, right?
Like rjardy says, you get what you put into it.
Old Jan 19, 2003 | 08:21 AM
SoulSurfer's Avatar
Default Re: Anyone's setup actually run perfectly? (rjardy)
Rob
Rob, hurry up and get back so we can do this
Old Jan 19, 2003 | 08:33 AM
rjardy's Avatar
uhhhh right why dont you get your butt out of KOREA!!!
Rob
Old Jan 19, 2003 | 08:55 AM
tony1's Avatar
The thing is, most people who post on here with their problems are doing this themselves, most for the first time. There are a lot of things that can only be learned from experience. I've done a ton of turbos, custom and kits, with no problems what so ever. On the other hand, i've seen a ton of cars that people have done themselves with all kinds of problems. Turbos can be reliable if done properly. Manufacturers wouldn't build cars with them if they weren't! If you don't know what you're doing then take it to someone who does. There's a ton of things you can do wrong and a lot of damage that can be done. I know everyone wants to learn and do it themselves, but you know as well as I do that some people just aren't mechanically inclined.
Old Jan 19, 2003 | 09:01 AM
SoulSurfer's Avatar
Default Re: Anyone's setup actually run perfectly? (tony1)
Isn't that the truth. I've never done a turbo install. I really haven't done much more than a U-joint and a carbeuretor on my old truck. My friend Rob (rjardy) will be helping me as long as he doesn't blow up his own car.
Old Jan 19, 2003 | 09:24 AM
rjardy's Avatar
Its not that hard, i wont blow my car up, promise or yours for that matter. I have never done a turbo install but lenty of engine installs removals clutches ETC. a bolt is a bolt an a nut is a nut ( thats asking for it ) fact is, if you know whats going on and are somewhat mechanically inclined you can attack about any project on your Honda. Dont worry Ben.
Rob
Old Jan 19, 2003 | 09:27 AM
LS-hatch's Avatar
You only see problem posts because why would someone make a post that says "hey everythings running fine, thank you." I think the majority of people with a turbo have it running fine, they are the ones who answer other peoples questions, and whatnot.
Old Jan 19, 2003 | 09:51 AM
IntegD's Avatar
New User
Default Re: Anyone's setup actually run perfectly? (LS-hatch)
Just a part of the game when you start putting on more mods than I/H/E. Put some serious horsepower and something stock is bound to give in due time. Not necessarily the motor, possibly axles, plugs, things like that. As long as its tuned well and you keep a pretty constant check on things, there shouldnt be many problems at all.
B00ST2nR
May 26, 2004 10:59 PM
turbo96wr
Apr 25, 2004 07:58 PM
Specail Ed
Dec 9, 2002 09:52 AM
ceemarun
Aug 1, 2002 08:52 AM
Scylla
Mar 19, 2002 12:20 PM
