anyone using nippon or supertech pistons for light boost ?
Old Apr 19, 2011 | 01:36 PM
99black_em1's Avatar
Default anyone using nippon or supertech pistons for light boost ?
hey im rebuilding the b16a , trying to do mostly stock parts to past CA smog easily. I was thinking of using stock cams , and stock compression pistons .. and use the stock ecu and stock CAT to pass smog, and then unbolt everything , install a log manifold with a gt28r, and a s300 to have some fun. this is a budget build for a daily driver and every penny saved counts ! ..
- after researching , ive read that the nippon pistons are great quality and similar to an OEM piston ( but much cheaper ) ! and have stronger ringlands ... and the supertech piston seems to be a much cheaper forged piston .. i plan on using stock rods
my goal is to keep it around 10:1 compression so it would run correctly with the stock ecu , and with the turbo , im not lookin to push pass 300-320whp with the gt28r.
Has anyone used the nippon piston or supertech piston before ? .. please share your experience with them or any other type of feedback. thanks !!
Old Apr 19, 2011 | 02:07 PM
Turbo-LS's Avatar
Default Re: anyone using nippon or supertech pistons for light boost ?
the HP levels your looking for are achieveable on stock internals so supertechs would be that much stronger
Old Apr 19, 2011 | 02:24 PM
sc34dc4's Avatar
Get Nippons and have them machined for the C clip and run aftermarket rods. There is a member on here who made like 480 on them.
Old Apr 19, 2011 | 04:35 PM
deeweezy187's Avatar
there is somebody running these in i think either a type r or a lsvtec he was recently in a magazine hes running them and i think made 500+. i might use them for my b18b1 build.
Old Apr 19, 2011 | 04:47 PM
dk=gsr's Avatar
i have low comp. nippon pistons.
they're do what you need them to do.
but mine are oversized.
Old Apr 19, 2011 | 04:48 PM
dk=gsr's Avatar
oh yeah and one of my buddy was using the same pistons on his 320hp boosted gsr too.
could of pushed it more but he didn't trust the pistons.
Old Apr 19, 2011 | 07:00 PM
if I decide to use the nippons , I plan on using the gsr pistons, not the LS to keep it at 10.1 compression and stock gsr rods . is that still safe for 320 whp for a daily driver ?
Old Apr 20, 2011 | 08:33 AM
sc34dc4's Avatar
Yes you'll be fine. If you're tearing into the motor to rebuild it then might as well do rods at the same time. Then you will be set to make a lot more power. "assuming the rest of the setup will support it"
Old Apr 20, 2011 | 10:14 AM
where can i get nippons machined to fit eage rods?
Old Apr 20, 2011 | 11:56 AM
MR.johnson's Avatar
i have been making 500 for the last 2 years on my supertechs.
Old Apr 20, 2011 | 12:16 PM
GEN2 LS's Avatar
Loved
the company that sells the pistons on ebay should be able to last time I checked. i'm running a b16 stock rods, with nippon ctr replica pistons my car is making 340whp runs fine!
Old Apr 20, 2011 | 01:52 PM
wow nice ! .. a few questions :
- are the nippons actually stronger than the OEM honda pistons >?
- do the nippon rings require filing or do they come in specs like the OEM honda ?
Old Apr 20, 2011 | 03:31 PM
Mr.Spec's Avatar
i doubt nippon are stronger than stronge than OEM, they're simply a direct copy
Old Apr 20, 2011 | 03:55 PM
wantboost's Avatar
Who is Mr Robot?
the nippon pistons are not oem copies... they are stronger... try making 500hp on stock cast pistons... reliably
they have stronger ringlands, are cast differently and feature lower compression ratios.
Old Apr 20, 2011 | 04:01 PM
Turbo-LS's Avatar
its basically an upgraded LS piston. Same compression with stonrger, thicker ringlands. in any case not the same as oem.
Old Apr 20, 2011 | 04:27 PM
turbohatch96y7's Avatar
Good info in this thread!!!
Old Apr 20, 2011 | 04:33 PM
wantboost's Avatar
Who is Mr Robot?
lemme see if i can find the build thread where the guy made stupiud power
Old Apr 20, 2011 | 04:44 PM
i asked them awhile ago he they said they couldn't.
Old Apr 20, 2011 | 05:02 PM
wantboost's Avatar
Who is Mr Robot?
Theyve done it before
Old Apr 20, 2011 | 05:09 PM
dk=gsr's Avatar
no the rings don't need grinding or filing.
Old Apr 20, 2011 | 05:10 PM
the Nippon pistons u guys are refeering to .... are they the NPR ( Nippon piston rings ) brand .... or are they the Nippon racing brand ?
- to the guy making 500 on supertech pistons ... r u making it with stock rods or eagle rods ?
thanks for the responses
Old Apr 20, 2011 | 06:52 PM
welfarepc's Avatar
ALL rings should be gapped.
it doesnt matter the brand. installing rings without checking the gap first is NOT how it should be done.
Old Apr 21, 2011 | 08:14 AM
Turbo-LS's Avatar
If your making that kind of power dont cheap out on rods by using oem. for 300 bucks can get eagles and have a strong bottom end. turbocharging isnt cheap especially when you want to start making good power. you cant have a cheap reliable fast car, just doesnt happen
Old Apr 21, 2011 | 09:53 AM
MR.johnson's Avatar
eagle lol.
Old Apr 22, 2011 | 01:42 AM
bump ! .. you guys that seem to be having luck with the nippon pistons ... are they the NPR (nippon piston rings ) yellow boxed pistons ? ... or the nippon racing (white boxed) pistons ?
