Anyone using Jackson Supercharger in there B Engines
I have an B18C5 Engine running a JSRC at 10.4 psi making 223 whps. My Manifold is leaking coolant due to the previous owner doing a bad job drilling the holes. My manifold is a GSR.
Last edited by tech8; Sep 24, 2022 at 03:52 PM. Reason: This is not the marketplace.
For the B series both the ATI Procharger kit and Kraftwerks kit are much better options.
If you’re just going for a 13 or 12 second time in the quarter mile, then a supercharger is good too.
So it depends what type of use you want out of it. It could be useful for smaller track road racing too.
Here’s a super long thread about them:
https://honda-tech.com/forums/forced.../#post52602868
Most people I’ve seen with these superchargers are maxing out around 300whp at most, and most people are in the 200-300whp range, although if you have a good All-Motor type set up with a supercharger added on that, you could push over 300whp, but I don’t think more than 350WHP or 400.
I'd be interested to see if anyone has ever taken these over 300WHP, it's been a long time since I've looked through the thread you linked. I could be wrong as I'll admit this is entirely off speculation/observation.
I've seen a few Kraftwerks supercharged B and K engines make good power in the 400-450 range. I was strongly considering going supercharger instead of turbo when planning out my hatch, but wanted to retain AC and the Kraftwerks kit mounts where the OEM compressor goes. The Procharger kit may have worked well for me, but ended up going small turbo for (reasons).
@wunfastgsr Has a really nice build, pretty sure he's been on the ATI Procharger for years now - don't remember his WHP results but it's a really nice car.
@JRCivic1 Also has a lot of experience with supercharged Hondas.
It's been a really long time since I've seen anyone try a twincharged build.
Dont think ive seen a successful one completed. Before i joined in 09 at least. Didnt notice anything prior either. Would prolly be rad though
Wasn't common but was common enough with 03/04 Cobras to know it works. Twin screw/roots helps get it going with torque and then the turbo takes over.
Power limitation comes with the supercharger/intake setup restricting the turbo over a normal intake.
I don't think I've ever seen anyone push over 270-280 on a B series JRSC, and if I remember right the guy pushing those numbers had a lot invested into that system and did a lot of extra things to optimize it. Most often I see people making anywhere from 210 -> 230WHP on these kits, even 240+ seems very rare.
The best QT I was able to put down was a 12.8 with this setup and altogether the setup cost me damn near 5k, I ended up selling the entire kit to a guy in England for $3,500 bucks and was happy I did so. At the time I found a guy selling a little Garret 57 trim turbo kit with ram horn manifold for 1K. This kit came with everything, intercooler, piping, wastegate, blow off valve etc. After I installed the kit, I took it to get tuned and made 480whp with the setup, went to the track and ran an 11.6 first time out with it.
From there on out I never looked back LOL..
So in 2005 I actually ran a Jackson Supercharger on a sleeved 10.5:1 compression motor with fully ported head. I had Endyne port the supercharger and I even ran the LHT Performance Air to Water intercooler setup for it. My setup made 280WHP BUT I hated the performance. Even with the LHT intercooler the car had horribly high IAT temps and would heat soak, my LHT Performance intercooler would always leak and had to be fixed by John at LHT multiple times.
Kraftwerks has the most power potential but (completely anecdotal) I heard from Jeff Evans that those units are prone to some problems of their own in our cars and he's had multiple customers who have to send their superchargers out for rebuilding every ~5K miles
Yeah that about sums up every other experience and result I've read from the JRSC on our cars. It's too bad the ATI Procharger kit never got more attention for the B series, wunfastgsr seems to have had extremely good results with his and overall it seems to be a much more capable kit than the JRSC while still retaining factory comforts like AC.
I think even where, or specifically how high/low the supercharger is mounted relative to the rest of the pulley system even plays a factor. And then of course you have to consider belt grip, grooves, widgth, etc. Been awhile since I've looked into superchargers on these cars, they seem cool but turbo is the path with more footwork and documentation behind it.
