Anyone using InlinePro headgasket?
I hear its a good headgasket..... anyone using it that has experience with the HG? Im planning on buying one but it is marked at 300 bucks at inlinepro.com. Does anyone else sell this HG on any other site besides their own? THX
I think I would search on this one man, lots of good answers to this subject in the archives.
I used one for a while, it was great cheap way to lower compression and let you run more boost but your only missing out on about 20-30whp compared to just running a stock headgasketed never opened block...
Like I said thou lots of good posts on this out there..
You could compensate for the higher comp. by running less boost. This way you would still make the same whp, just at a lower boost setting as compared to an identical setup with this headgasket. Just another way to look at it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8t »</TD></TR><TR><TD CLASS="quote">You could compensate for the higher comp. by running less boost. This way you would still make the same whp, just at a lower boost setting as compared to an identical setup with this headgasket. Just another way to look at it.</TD></TR></TABLE>
Thx and bump again
Thx and bump again
teamrocket si
Oct 16, 2001 12:27 PM
