anyone with a turbonetics tuner kit help!!!
Old Aug 21, 2006 | 10:35 PM
vtec_racer_2kgsr's Avatar
Default anyone with a turbonetics tuner kit help!!!
I want to know if the downpipe is 2.75in or bigger I'm hoping to join the 300whp club but my tuner said I need at least 3in downpipe. and he also said that the hondata heat shield is no good for boost is this true???
Old Aug 22, 2006 | 01:31 AM
HYBRID_H@TCH's Avatar
Default Re: anyone with a turbonetics tuner kit help!!! (vtec_racer_2kgsr)
I didnt say its was "no good for boost" I said sense I had a problem with it blowing out and water going in to number 4 cyl I wont use one again..I use them all the time on allmotor..but for turbo I do not trust them..
also you said the downpipe was 2.25 and I said 300 whp was going to be a no go..2.75 would do the trick..you have a dead stock motor that you are going to run on shitty CA pump gas..you cant expect much..but you got to remember..the better the flow of the exhaust (3 inch dp) the more power that can be made on the same boost.
Old Aug 22, 2006 | 07:45 AM
Default Re: anyone with a turbonetics tuner kit help!!! (HYBRID_H@TCH)
I see!!!
2slicc
Dec 5, 2012 02:23 PM
WH0R3nEF9
Apr 1, 2005 09:45 PM
F120man
Feb 8, 2004 10:11 PM
f22suzuka
Aug 3, 2003 06:15 PM
wonny
Jan 20, 2003 10:00 PM
