Anyone live in NC?? Question on emissions
Old Jan 11, 2021 | 06:19 PM
Stopsign32v's Avatar
Loved
Default Anyone live in NC?? Question on emissions
Well I'll be moving out of a free state into a state that requires annual emissions testing. I wanted to know specifically how turboing one of these cars works in NC. Does anyone own a turbo B series in NC?
Old Jan 11, 2021 | 06:56 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Anyone live in NC?? Question on emissions
depends on where you live and what your car is, vary by county. I'm assuming you're referring to your '98 Integra
Old Jan 11, 2021 | 10:01 PM
Txdragon's Avatar
I lived in Kernersville for a little shy of 3 years. Forsyth County if I remember correctly.. At that time, I don't remember having any emissions done..
Old Jan 12, 2021 | 08:37 AM
DaX's Avatar
DaX
Loved
Community Favorite
My experience is with GA and TN, but I agree with @NVturbo - requirements are going to vary by county. From my past experience, anything OBD2 (96+ Civics / Integras) will require a scan of the ECU through the canbus. This means that cars which are OBD2 > OBD1 converted will not pass emissions, as the canbus will not communicate with OBD1 ECUs. I have a friend who had a turbo EK and every year he would remove his turbo kit, reinstall stock components, and convert back to OBD2 about a month before emissions testing, then convert it all back after passing. He said it was a huge pain in the ***. This is why I have only turbocharged OBD1 and older Hondas over the years.
For OBD1 and older vehicles, since there is no canbus, you have to pass a tailpipe sniffer test. In GA, the car had to go onto a dyno to measure wheel speed and the emissions were tested at two different speeds. In TN, they test my tailpipe emissions at idle, so no rollers. This past year I passed with my turbo Civic while running E85 - I did lean out the idle just a bit to get AFR's around 14.5:1 - 15.0:1. Both GA and TN have used a mirror to check for a catalytic converter and pressure tested the gas cap. Currently I have a high-flow cat that I swap in for emissions day, and run a test pipe the rest of the year.
Different areas have different laws on when a vehicle no longer has to be tested, also. In GA, any vehicle made before 1976 and any vehicle that was 25 years old or older were exempt from emissions testing. Where I'm at in TN, a car can never "age-out" of emissions testing - it's only exempt if it's pre 1976. Thankfully they are planning to eliminate testing in my county all together in the next couple of years.
Old Jan 12, 2021 | 10:37 AM
Loved
Yes the 98 and we will be in Brunswick county.
Edit: !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Originally Posted by WECT News 6
September 28, 2018 at 11:17 AM EDT - Updated December 1 at 6:01 PMBRUNSWICK COUNTY, NC (WECT) -
Starting December 1, Brunswick County will be among 26 counties that will no longer require vehicle emissions testing, according to the North Carolina Department of Environmental Quality.
https://www.wect.com/2018/09/28/vehi...ntal%20Quality.
Old Jan 12, 2021 | 06:25 PM
NVturbo's Avatar
O.G. triple O.G.
just safety inspection then......working horn, windshield not cracked obstructing the view, turn signals, etc.
Old Jan 13, 2021 | 05:45 AM
Loved
This is about the only good news so far in 2021! Woohoo
raverx3m
Jul 19, 2015 03:32 PM
big_claw
Apr 9, 2008 09:43 PM
playahwitgame
May 30, 2006 08:44 AM
-1TSXer-
Aug 1, 2004 07:25 AM
MeanGreenEG9
Dec 4, 2002 11:16 PM
