Big difference?
Old Feb 21, 2003 | 06:15 AM
Lewie's Avatar
I'm here for the gangbang!
Default What's the deal with big intercoolers? Do they help?
I am looking into getting a turbo in the near future, probably a custom setup....I want to get about 350 whp total once I am done(probably a year down the road at least). I am thinking of going with a t3/t4 turbo instead of a t3/t04 turbo, so that it spools a little bit quicker, and I don't want to go over 350 hp cause it will be a daily driver. What do you guys think about that? Now my real question is that I am looking at intercoolers and I saw on this thread https://honda-tech.com/zerothread?id=412590 a huge intercooler on a yellow teg....I believe it's dimensions are 28x8x3.5. Will a big intercooler help me out that much, or should I just stick with the conventional intercooler from like a revhard kit? Can using a big intercooler actually cool it off too much where you are running at the right temp? I can use any input you guys have.
Thanks
[Modified by lewie4, 10:43 AM 2/21/2003]
Old Feb 21, 2003 | 06:59 AM
C-Murdock's Avatar
Default Re: What's the deal with big intercoolers? Do they help? (lewie4)
I beleive a T3/T4 is a T3/T04, just shortened...
You should get the right intercooler for your application. A revhard intercooler will be fine or something like 22x8x3 will work out. That intercooler isnt 3.5 deep its only 2.5 i believe or 3.
Check out the CFM Flow rate of your intercooler to see if it is efficent enough. Ive seen the intercooler I have which is a 24x6.5x3.5 Spearco Make 521whp@28psi without any detonation or pressure drop, so im sure you do not need to go too big..
Old Feb 21, 2003 | 07:01 AM
Lewie's Avatar
Default Re: What's the deal with big intercoolers? Do they help? (C-Redrum)
thanks....i figured a regular intercooler would work fine for what i want
ef dino
Apr 16, 2008 07:07 PM
DJaeMac
Honda Civic (2001 - 2005)
Sep 21, 2007 09:45 AM
cBrown05
Mar 25, 2007 09:16 PM
acy76
May 24, 2005 07:48 PM
Integra_Boi
Aug 9, 2002 08:12 AM
