Anyone have the ACT HDSS??
Old Jul 14, 2003 | 06:47 PM
integranator's Avatar
Default Anyone have the ACT HDSS??
I'm trying to decide which ACT clutch to go with. I'm worried that the HDSS won't be strong enough for the amount of racing that I do. I take the car to the track twice a week, but push it often. I'm only running 6psi on a t3/04e 57 trim, but i plan on running 9ish. Will this clutch hold up??
Old Jul 14, 2003 | 06:51 PM
VisualAutoMotoring's Avatar
Default Re: Anyone have the ACT HDSS?? (integranator)
yea it should hold up no problem for the time being....but i wouldnt count on it lasting for a long time
Old Jul 14, 2003 | 06:53 PM
TurboTegB18c's Avatar
I would definately recommend staying away from the heavy duty pp. At least go with the extreme pp.
Old Jul 14, 2003 | 07:07 PM
Default Re: Anyone have the ACT HDSS?? (TurboTegB18c)
Which clutch kit do u reccommend? and whats the difference between the hd pressure plate, and the extreme pressure plate?
Old Jul 14, 2003 | 07:11 PM
R-1303's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTegB18c &raquo;</TD></TR><TR><TD CLASS="quote">I would definately recommend staying away from the heavy duty pp. At least go with the extreme pp. </TD></TR></TABLE>
I'm running the xtss with extreme pressure plate and street strip cluch...that should hold up for awhile....the fell of the xtss is nice!,..not to stiff and very smooth in my teg. While its out u might want to consider a lighten flywheel..and try to stay away from puck discs.
Old Jul 14, 2003 | 07:36 PM
Default Re: Anyone have the ACT HDSS?? (R-1303)
If i got the xtss, do I have to get a flywheel?? because I think thats the clutch i'm going to get now.
Old Jul 15, 2003 | 08:15 AM
RyanEJ8's Avatar
Why do you say that?
Old Jul 15, 2003 | 08:51 AM
Daniel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integranator &raquo;</TD></TR><TR><TD CLASS="quote">If i got the xtss, do I have to get a flywheel?? because I think thats the clutch i'm going to get now.</TD></TR></TABLE>
You can use your OEM flywheel; just make sure to get it resurfaced. I'm using the HDSS with the stock flywheel, and I like it. It can feel a little soft at times, but it still grabs just as good now as it did when I first bought it some 10000 miles ago. It held up great while I was boosting 5-7 psi (with a 10 psi spike) and still feels good now that I'm back to NA. The pedal feel is slightly stiffer than stock but still very streetable. The HDSS kit for my car can hold up to 223 lb-ft of torque, and that's way more than I'll ever see.
Old Jul 15, 2003 | 11:17 AM
mike1114's Avatar
Default Re: Anyone have the ACT HDSS?? (Daniel)
get the xtss street/stip dics. You'll kick yourself if you don't. what if you decide to up the boost later (everyone does!!) that HDSS clutch won't hold long.
Get the xtss for sure.
Old Jul 15, 2003 | 11:23 AM
DIRep972's Avatar
Smarter than you
Ive been using the HD/SS for like 20 months. I race ALOT. Ive put down over 240ftlbs of torque on the HD/SS and never had a single problem with it. I couldn't be happier with that clutch. Ive seen people ruin act clutches fast but I think its because of bad driving. If u break it in properly and don't slip it, it will hold alot of power and last a long time. Next set up is going to be around 300ftlbs torque and I am going to use the extreme/street strip because i have had such good luck w/ the heavy duty.
Old Jul 15, 2003 | 12:17 PM
g2turbo's Avatar
Default Re: Anyone have the ACT HDSS?? (DIRep972)
ihave the XTSS and i love it
Old Jul 15, 2003 | 12:33 PM
JDEM1's Avatar
Default Re: Anyone have the ACT HDSS?? (g2turbo)
i have xt/ss on my bone stock 00 si... haha it feels great.. cant wait to put my turbo on now..
Old Jul 15, 2003 | 12:50 PM
95c1v1cs1's Avatar
Default Re: Anyone have the ACT HDSS?? (JDEM1)
any more opinions?
Old Jul 15, 2003 | 01:45 PM
silverEH2's Avatar
i had one but i never got to use it
tegasaurus
Aug 29, 2007 07:33 PM
whiskaz
Dec 16, 2006 01:55 PM
NAturalDC2
12
Jun 9, 2005 04:37 PM
bboylito
Apr 10, 2005 05:47 PM
GraphiteAccord
Feb 12, 2003 10:56 AM
