Anyone ever install a missing link
Old Oct 2, 2001 | 09:48 PM
NeXtLeVeL_TyPe_R's Avatar
Default Anyone ever install a missing link
I am looking to install a missing link map bypass. I hear that this is a better option then common check valves. I cant seem to find any info online on how to go about installing it. Anyone know any place online or have done it themselves and can help.
Thanks in advance you are all very helpful
Old Oct 2, 2001 | 09:50 PM
dustin's Avatar
Default Re: Anyone ever install a missing link (NeXtLeVeL_TyPe_R)
You unscrew the map sensor (2 screws) and put the missing link between the throttle body and the map sensor. Then you tighten it down with the 2 longer screws they give you.
Dustin
Old Oct 2, 2001 | 09:53 PM
seems pretty easy and alot less involved then all the check valves thanks for the help dustin.
as you can see i found the caps lock key
thanks again
Old Oct 2, 2001 | 09:54 PM
dustin's Avatar
Yes I am glad the caps thing got cleared up. A pet peeve of mine (everything is a pet peeve to me).
Yeah the missing link is easy to install. No check valves to fail... it is aluminum and looks cool too
Dustin
Old Oct 2, 2001 | 09:57 PM
so nothin hooks up to that aluminum piece it pretty much just acts as a spacer correct? and that tricks the map sensor reading. Pretty cool product
Old Oct 2, 2001 | 09:58 PM
dustin's Avatar
It actually has a heavy duty check valve built into it.
Dustin
Vinhtran17
Mar 30, 2004 09:30 PM
Private50
Nov 2, 2003 06:11 PM
ludelvr
May 31, 2002 06:20 PM
yellow blur
May 21, 2002 09:52 AM
FBP Si 2000
Oct 2, 2001 08:09 AM
