Anyone else lose power using FILTER???
Old Mar 16, 2004 | 01:07 PM
  #26
FredoSP's Avatar
Default Re: Anyone else lose power using FILTER??? (94gsr4dr)
ive seen the apexi filters on Supras, are we SURE we all know what we are saying? Doesn't a filter create a velocity stack for the air coming into the compressor housing?
Bump to get flammed
Old Mar 16, 2004 | 01:22 PM
  #27
The Shodan's Avatar
Default Re: Anyone else lose power using FILTER??? (g5r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g5r &raquo;</TD></TR><TR><TD CLASS="quote">anyone use the real hks filter, the green mushroom filter? how is it?</TD></TR></TABLE>
I'm using it on my Integra . I've noticed no power loss
Old Mar 16, 2004 | 02:09 PM
  #28
mildly.interesting's Avatar
I run no filter, and when I put the K+N on, it felt like I lost 50 hp...I burnt my arm taking that piece of **** off because I wanted it away from my car as quick as possible...
Old Mar 16, 2004 | 02:18 PM
  #29
Project91CRX's Avatar
I rather stick with an Apexi Filter
Check out the test.
You're better off running no filter than having the HKS Filter.
http://mkiv.com/techarticles/filters_test/2/
Old Mar 16, 2004 | 02:26 PM
  #30
g5r's Avatar
g5r
Default Re: (Project91CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project91CRX &raquo;</TD></TR><TR><TD CLASS="quote">I rather stick with an Apexi Filter
Check out the test.
http://mkiv.com/techarticles/filters_test/2/</TD></TR></TABLE>
i did not know the hks filter is that bad. i would of thought it is great cus of the brand.
Old Mar 16, 2004 | 02:37 PM
  #31
spoolinlude's Avatar
I live under a rock
Default Re: (g5r)
Apparently on ian's (clendaniel) car his air filter actually collapses at boost......he made 2 dyno runs, one with one without....... made around 14 more horse without the filter
Old Mar 16, 2004 | 03:15 PM
  #32
TABIAS's Avatar
I want to be MADE into Ice-T
Default Re: (spoolinlude)
wow that apexi filter looked good on that test, i think im gonna pick one up for my new set up
Old Mar 16, 2004 | 03:29 PM
  #33
USDM 4G VTEC's Avatar
Default Re: Anyone else lose power using FILTER??? (envision2teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by envision2teg &raquo;</TD></TR><TR><TD CLASS="quote">apex is the best filter out there, better than the K&N so you shouldnt have the problem you are having</TD></TR></TABLE>
wich one are u getting????
i dont know about apexi
but the K&N i have flows 950 CFM
much more than waht the engine and turbo will be flowin
so i dont see how much it will be loosing power
Old Mar 16, 2004 | 04:15 PM
  #34
Honda Hick's Avatar
Default Re: Anyone else lose power using FILTER??? (-iLLuZioN-B18C1)
If ya need a K&N go here - http://www.performanceintl.com/shop/index.html
They have like 3000 sizes of universal K&N filters. Get the biggest you can fit and it'll flow the most.
Old Mar 16, 2004 | 05:06 PM
  #35
psileepR's Avatar
New User
Default Re: Anyone else lose power using FILTER??? (Honda Hick)
i just picked up an apexi filter. I hope it performs as well as some people on HT say.
https://honda-tech.com/zerothread?id=800708
i am currently using a K&N cone filter.
Old Mar 16, 2004 | 05:16 PM
  #36
-iLLuZioN-B18C1's Avatar
Default Re: (mildly interesting)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mildly interesting &raquo;</TD></TR><TR><TD CLASS="quote">I run no filter, and when I put the K+N on, it felt like I lost 50 hp...I burnt my arm taking that piece of **** off because I wanted it away from my car as quick as possible...</TD></TR></TABLE>
seriously, when i put on the apexi, it is COMPLETELY night and day.
makes me not even, once i felt how my car pulls without the filter, it
really feels like i lost 40whp. without the filter it just pulls that much harder.
you know the feeling when you hit boost and your steering wheel starts swirving?
that feeling is completely gone after i threw on the filter.
  #37
b18bturbo's Avatar
Default Re: Anyone else lose power using FILTER??? (psileepR)
dont ever use those cheap style filter i tried it and it ***.
i like the S&B, apex and K&N
Old Mar 16, 2004 | 06:36 PM
  #38
Default Re: Anyone else lose power using FILTER??? (b18bturbo)
someone IMed me and brought up a point.
my tuner tuned my car without filter, so a/f ratio was good.
i slapped on the filter, which will somewhat affect the a/f ratio correct?
i felt a big loss in power.
so if i go retune, with the filter on, and get the a/f ratio back to where
it needs to be, do you see me being able to get that 'loss' power back?
Old Mar 16, 2004 | 09:41 PM
  #39
Dr. EKology's Avatar
There is also 2 different sizes (that I know of, there probably is more) for the Apex'i intake. 80mm and 85mm, if not bigger ones for different applications. Measure yours and see what yours is, that may be your problem.
Old Mar 16, 2004 | 10:15 PM
  #40
94gsr4dr's Avatar
Default Re: Anyone else lose power using FILTER??? (EVIL_EKology)
If you really feel like you are losing that much power, then just take the damn thing off. Take your chances and put a screen on it. I know people that have driven years with only a screen.
Old Mar 17, 2004 | 11:55 AM
  #41
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVIL_EKology &raquo;</TD></TR><TR><TD CLASS="quote">There is also 2 different sizes (that I know of, there probably is more) for the Apex'i intake. 80mm and 85mm, if not bigger ones for different applications. Measure yours and see what yours is, that may be your problem. </TD></TR></TABLE>
i assume you are talking about theopening on the filter. im sure i got the 85mm one since i do know it is bigger than 3"
Old Mar 17, 2004 | 05:34 PM
  #42
adhana2's Avatar
just run some stockings
Old Mar 17, 2004 | 07:02 PM
  #43
Smashback's Avatar
Default Re: Anyone else lose power using FILTER??? (adhana2)
Japan, much like China, land of the gimmicks. I really have a hard time putting my faith in some test run by a Japanese guy and a vacuum cleaner or whatever. What happens to the dirt that the Apexi filters out? Does it dissintegrate? Does it fall off? I don't get it. K&N is dyno proven. I'm not going to argue it over and over, but I thought I'd give some input. Whoever said "apex is the best ever" (or whatever) is talking out of his ***. I doubt he has seen a more realistic and controlled test performed, much less dyno results.
Call me a filter **** ... I'll stick with K&N
Also..foam filters sucked. They sucked back in the 60s, and they still suck today. They filter for crap, and they fall apart with time.
Also, might just be me but the K&N doesn't look like it's oiled in the test picture.
Either way....they state that the Apexi is zero maintenence, which is physically impossible.
Enjoy
Old Mar 17, 2004 | 11:08 PM
  #44
_Endless_'s Avatar
i'm using the HKS super powerflow mushroom filter and i didn't notice any difference. when i had my car for dyno tuning, the tuner took the filter out to see if there's any difference in power but there was no difference.
Old Mar 27, 2004 | 09:40 PM
  #45
psileepR's Avatar
New User
Default Re: Anyone else lose power using FILTER??? (_Endless_)
just installed my apexi air filter and whoa what a difference. it feels like it spools up a lot quicker now. or maybe it was my old filter was too dirty. but anyways i like the results.
Old Mar 28, 2004 | 04:13 AM
  #46
MiraiZ's Avatar
What were you using before? I'm using this crappy Tenzo K&N look alike POS. Never dynod with any other filter, but now this post is making me wonder if I could be making more power with a better filter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psileepR &raquo;</TD></TR><TR><TD CLASS="quote">just installed my apexi air filter and whoa what a difference. it feels like it spools up a lot quicker now. or maybe it was my old filter was too dirty. but anyways i like the results.
Old Mar 29, 2004 | 12:57 AM
  #47
MiraiZ's Avatar
Default Re: Anyone else lose power using FILTER??? (MiraiZ)
bump for curiousity
Old Mar 29, 2004 | 08:19 AM
  #48
quikB18B's Avatar
Thats exactly how I felt the day I got mine
Not that it's a honda but my friend(Turbo miata) whos making pretty good power, switched from on open velocity stack to an Apex. Actually the were on the dyno, tuning the car, and he had the Apex in the car, so out of curiosity they slapped it on to see what happened and bam, he gained I think it was 14-15 hp simply by adding the Filter.
For the locals im talking about Andrew that worked a Jotech with the Red turbo Miata.
Old Mar 29, 2004 | 11:09 AM
  #49
psileepR's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ &raquo;</TD></TR><TR><TD CLASS="quote">What were you using before? I'm using this crappy Tenzo K&N look alike POS. Never dynod with any other filter, but now this post is making me wonder if I could be making more power with a better filter
i was using an S&B filter. the 6" long cone with a 3" inlet.
oh and i dont know if this matters... but my car now sounds like a pissed of snake. hissing and stuff @ idle lol
Old Mar 29, 2004 | 11:27 AM
  #50
im running the apexi right now. i just ordered a k&n filter. it is going to be a much
bigger one. i will tell you what the butt dyno says comparing the two (even though it isnt that fair of a comparison b/c k&n will be bigger)
but ill tell anyways
